Question about LXE VX9 Forj Data Terminal VX9B9P1A2F2A0AUS PC Notebook
The touchscreen not responding - LXE VX9 Forj Data Terminal VX9B9P1A2F2A0AUS PC Notebook
Touchscreen not responding. Frozen
Two thing can cause this. If your unit is running firmware version 5.3, this version has a bug where the touchscreen will work for about 5 seconds then the unit will lock up. Updating the unit to version to version 5.4 will fix the problem. More info can be found here:
http://www.sharc.net/discus/messages/6/471.html?1337567850
http://www.sharc.net/discus/messages/6/469.html?1333569932
If you are running firmware version 4.9 or 5.4 and the touchscreen still does not respond, then the touchscreen will need to be replaced. On the Nuvi 7xx, the touchscreen may be soldered to the LCD display, so if you don't have any soldering experience, please have a professional replace the touchscreen. More info can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Mar 23, 2013 | Garmin Nuvi 760 Car GPS Receiver
Touchscreen doesn't respond
Sounds like it didn't install correctly, you may want to check the digitizer on the glass panel
Oct 06, 2012 | Motorola Mobility DROID BIONIC (16 GB)...
Touchscreen does not respond to touch .
CHECK THE FLEX OF UR TOUCHSCREEN IF ITS BROKEN;IF NOT JUST LIFT THE SOCKET AND PLACE IT AGAIN.
Jul 27, 2012 | Handspring PalmOne palm treo 600 Silicone...
My buttons on my phone works but my touch screen is not responding to anything at all.
check MENU settings may be touchscreen is off ,else touchscreen loop is broken
Aug 02, 2010 | Cell Phones
The touchscreen will not respond, but there hasnt ...
You may not see the damage but, it might have been damaged somehow. Take it to phone shop to be examined. Thanks
May 20, 2010 | Lands Phones
The touchscreen no responds
Try going into settings and go back to factory default,See if that resets your phone (but make sure you back up your contacts just in case you lose them.
Mar 07, 2018 | LG Xenon GR500 Cell Phone
Try to find how to calibrate the touch screen in the users manual.
May 29, 2009 | Garmin nuvi 250W GPS Receiver
Treo600 Touchscreen doesn't respond.....
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus
Jan 14, 2008 | Palm Treo 600 Handheld
LXE VX9 Forj Data Terminal VX9B9P1A2F2A0AUS PC Notebook Logo
21 people viewed this question
Top LXE Computers & Internet Experts
David Payne
David Payne
Are you a LXE Computer and Internet Expert? Answer questions, earn points and help others
