Question about HP PSC 1350 All-In-One Thermal Printer
Monitor how to solve monitor no power and no display or else..
  • 363 Answers
Could you explain that a bit better?
Posted on Sep 26, 2007
SOURCE:
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
My monitor won't come on. When i power up my computer i don't get any display. I've tried replacing the video card but that still doesn't solve the problem.
Hello.
Try your monitor and cable on another computer to see if the problem is the monitor or VGA cable.
Is there power on the monitor but the display is dark ?
Hope this helps.
Aug 17, 2010 | Dell OptiPlex GX400 (2090246019) PC...
LG CRT 17'' power blinking and display problem
visit these sites for technical support:www.e-repair.co.uk/tips.htm, www.techtree.com › HomeBasicsMonitors
Jul 20, 2010 | LG 700M 17" CRT Monitor
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
V7 - S20PD TFT Monitor - Display goes off after about an hour
Hello, I am sure that you have some software settings problem. go to - DISPLAY PROPERTIES - SCREEN SAVER - MONITOR POWER. There select NEVER TURN OFF monitor. Your problem will be solved. BYE
Oct 10, 2009 | Computers & Internet
Monitor turn off after a second
Try to disconnect the monitor and check if the message to connect the cable stays on the screen. I will need more description to solve this. Like Is the monitor's power ON and the display goes off? Is it that the display goes off after windows booting process starts?
Aug 31, 2009 | Computers & Internet
On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Aug 29, 2009 | AOC 917Sw 19" LCD Monitor
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Dull display
I have lg studioworks 57M monitor. The main Problem was No Display, No Power Light.What was the Problem? Can give the technical solutions? just email as [email protected]
Oct 28, 2006 | LG Studioworks 57M Monitor
HP PSC 1350 All-In-One Thermal Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
