Question about Ovens
Kenmore model 362.7361193 oven and broiler has no heat range
SolutionGuy
  • 331 Answers
SOURCE: Broiler Works/Oven Doesn't
Jrzy, even though you can see the bake igniter glowing, that doesn't mean it's good. Igniters actually get weak (unlike a light bulb that simply burns out). It's hooked up in series to a safety valve (the valve that allows main gas into the oven) which actually reads the amps flowing through the igniter. If the igniter is weak and the amps are too low, the valve won't open up. Replace your igniter and you'll be cookin' with gas again. Tip---> before you unscrew your old igniter, put a little liquid dish soap on the threads for lubrication. This'll ensure it comes out with no problems.
Posted on Sep 15, 2007
vitg55
  • 78 Answers
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Posted on Dec 10, 2008
  • 530 Answers
SOURCE: Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Posted on Jan 04, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 07, 2010
tbirdfan1
  • 3051 Answers
SOURCE: F3-error. Kenmore classic oven
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Posted on Jun 20, 2010
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Does the top element turn on during pre-heat on an Kenmore 790.92 range
No, the top element was designed to only work on the broiler setting.
Sep 20, 2014 | Ovens
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
