Question about Dishwashers
Dishlex dx103 runs for first wash cycle then stops and start light flashes
  • 18 Answers
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Posted on Feb 04, 2007
  • 58 Answers
SOURCE: Frigidaire Dishwasher Console/Lights Flashing
which light flashes?
Posted on Nov 02, 2007
Rotu
  • 175 Answers
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Posted on Nov 06, 2007
  • 188 Answers
SOURCE: Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
SOURCE: Dishlex Global 300 - stopping mid cycle
This problem is common to both the 300 & 310 models. The flashing Fast light indicates a blockage in the water supply. I fixed this by:
- disconnecting the dishwasher
- checking for blockages in the input hose filter (there were none)
- removing the bottom of the dishwasher (two screws at the front)
- looking for the translucent plastic bucket thing attached to the side of the main assembly
- unclipping it from the main assembly and removing the white hose attached to it
- flushing 5 years worth of evil gunk down the sink (you need a small brush or piece of wire to get it out
Gabriel
Posted on Jul 28, 2009
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
I want to download a Dishlex DX103 dishwasher manual
want to know as this is my first dishlex dishwasher dx103. As there is no instruction manual being a rented property i want to know how to get solution on my problem. Was working last night but went to put a load on this morning but now have lights and thats it no cycle please help.....
Sep 19, 2009 | Electrolux Dishwashers
Dishlex 300 eco light
pump auto starts if overfull
sound like the machine is overfilling
check the level ,u may need to clear pressure line
or it may be bocked with gunk
if u dont know call for service
it shouldn't be a major.
Jun 16, 2009 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Owen Barnes
