Question about Hotpoint HSS25GFP Side by Side Refrigerator
Side by side hotpoint model #HSS25GFTA WW not cooling. Fan is running. Compressor is running but both lines are warm.
5 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: HotPoint model HSS25GFTBB fridge warm freezer cold?
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 02, 2008
docjohn174
  • 943 Answers
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Posted on Sep 27, 2008
  • 16 Answers
SOURCE: I have a Hotpoint HSS25GFPEWW side by side.....
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Posted on Aug 15, 2012
richroth
  • 9472 Answers
SOURCE: I have a Hotpoint model HSS25GFPAWW. It stopped cooling, fridge and freezer side. Removed the back panel, fan was not on and compressor was hot.
Unplug the refrigerator, remove the relay from the compressor and give it a shake. If it rattles, it is bad and needs to be replaced. Here is that part. But, since you said the fan was not running I suspect the control board is bad. Here is a link to that part also.
Keep me posted as to your findings.
Posted on Oct 19, 2012
Replaced control board in Hotpoint Model HSS25GFTA. front controls now operate and compressor is on and fan inside unit is working, but fan in bottom has not come on, how longwill it take before it does...
It should be easy to replace. However, Condenser fans are "usually" very robust fans. It should come on with the compressor unless the environment is below freezing (but not likely a feature). I would double check all electrical connections to and from compressor and Condensor fan. the outside bottom fan near the compressor. If it continues you may jeopardize the compressor. It is not made to run without the condenser cooling fan.
Mar 06, 2015 | Hotpoint Refrigerators
Not cooling, compressor is running but both lines are warm. fan is running also.
Check refrigerant pressure, if below 0psi (hg), need refrigerant, if not work before you charge up to 1.8 to 3 psi may be you has an escpape in the condensor internal lines, you can do this with 3 in 1 valve to refill and check the low pressure side
Oct 17, 2013 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
I have a Hot Point refrigerator model No. HSS25GFTA WW. I changed the filter but water still not coming out of the despencer, every thing else is working normal.
Sometimes you will need to purge the air out of the line after changing the filter. Just hold down the water dispenser for a few seconds every hour or so.
Jan 30, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
My frig blows alot of heat from the bottom is there another coil or sumthing that should be cleaned regularly besides the coil in the back behind the card board backing? my model number is off jus a bit...
Hello, Thank You for using FixYa. I will be helping you today.No thats it make sure its clean in back and under the front. Also make sure the condenser fan is running when the compressor is running. This is the fan in back behind the cardboard back. It should run with the compressor.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer has to be thawed out every 2 to 3 days. The refridgerator side isn't staying cool enough to keep milk from spoiling. It is a Hotpoint Model #HSS25GFTA WW and is only 2 1/2 years old. It is a side...
Could be multiple problems. First, check the freezer compartment and make certain that the freezer fan is running. This fan moves cold air from the freezer compartment to the refrigerator. If it's not running, inadequate cold air gets to the refrigerator.
Your having to defrost manually sounds like there could be a problem with the defroster circuitry; however, check out the fan operation first.
The fan should be at the top of the freezer. There is probably an access panel you can remove to see if it's turning. However, you should be able to hear it if it's turning.
If the fan is not turning, you will need to remove it and replace it.
Oct 11, 2009 | Refrigerators
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Not cooling
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
