Question about Samsung Televison & Video
2005 mitsubishi tv
Just bought a new Samsung Blu-ray player, but there is no way to hook it up to my 2005 Mitsubishi tv. Are there any type of adapter cables that would solve this?
    Scholar:
  • 124 Answers
I'm assuming that your new blu-ray player only has an HDMI port and your TV does not. In that case, does your tv have a component cable output? This should be five plug-in ports (red, white, red, green, blue). Amazon sells an HDMI to component adapter that you can buy here: http://www.amazon.com/eForCity-538581-HDMI-Cable-5-Feet/dp/B005QWH4QA/ref=sr_1_1?ie=UTF8&qid=1382102257&sr=8-1&keywords=hdmi+to+component+cable
Posted on Oct 18, 2013
  • jbayjason
    jbayjason Oct 28, 2013
    what if the tv only has the 3 component cable ouput -- red/white/yellow -- is there a connection from HDMI port on player to the 3 output on tv?
  • Chris Brewer Oct 28, 2013
    I'm sure one is out there but there would be no point in hooking up a Blu-ray player using RCA (r/y/w) analog cables. It would be like hooking up a tape deck to a $3,000 Bose surround sound system. Plus, the player is sending out a digital signal while your tv can only support analog. You will need to either buy a new tv or stick with DVD.
    New Friend:
    Problem Solver:
  • 9 Answers
I like it: http://topipod.blog.com/
Posted on Mar 17, 2014
  • 45 Answers
SOURCE: firmware update
Here's the link to the newest firmware.
http://tinyurl.com/54a9wo
Posted on Jun 15, 2008
Agent Jason
  • 78 Answers
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Posted on Jul 23, 2008
John-INSG
  • 312 Answers
SOURCE: how to hook up insignia blu ray player to netflix
This model player (NS-BRDVD) is not Netflix capable. Netflix capable models are NS-BRDVD3, NS-WBRDVD, and home theater system NS-BRHTIB.
Posted on Mar 10, 2010
SOURCE: Salt blu ray will not
Update your FW to at least 100112.01.XSS
Posted on Jan 10, 2011
SOURCE: Samsung Blu ray code for direct tv remote
is there any remote that i can program tv,cable,direct tv,and blu-ray player all in 1
Posted on Jan 27, 2011
Hi. I just bought an LG OLED TV and a Samsung UBD-K8500 Blu-Ray player, and can't hook them up.
Get a HDMI cable and use it to connect them. Your TV owners manual will show you a connection diagram.
Oct 19, 2016 | Samsung UBD-K8500 Native 4K Wi-Fi Built-In...
Can you hook up a blu-ray player to a Samsung TX-R2765 TV? I don't see an HDMI plug.
HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video AV CVBS Adapter HDMI 2 AV Converter Supports PAL/NTSC for HDTV DVD Amazon com HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video...
Nov 19, 2017 | Televison & Video
Samsung txp3071whx xxa
You can buy a A/V to HDMI converter to connect in between.
Jun 07, 2013 | Televison & Video
Bought blu ray player but tv doesn't have hdmi input
Try a S-Video cable for the video output.Use a RCA cable for audio output should work simular.
Feb 06, 2010 | Mitsubishi VS-70803 70 in. Rear Projection...
Is there a way to take advantage of Blu-Ray players with this TV? Is there an adapter that takes the HDMI coming out of the player and allows you to connect to the TV (at least I did not see any HDMI...
Yes, you can purchase a cable with the Mitsubishi's DVI terminal on one end an an HDMI terminal on the other, allowing you to connect HDMI Blu-Ray players. I've have the cable for years and it works great.
Jan 23, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 65413 loses convergence calibration
That model Mitsu doesn't accept 1080p input or 720 p input.You would need to chnge the output resolution on your bd player to correct this.
Dec 01, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
Televison & Video Logo
139 people viewed this question
Jerry Greenberg
Jerry Greenberg
