Question about Dryers
Auto feature does not work with heater setting
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 179 Answers
What type of heater and/or fan...
Posted on Oct 18, 2013
The heater will not kick on in auto setting
HAS IT ALWAYS BEEN LIKE THIS OR JUST RECENTLY STARTED DOING THIS?
Dec 27, 2012 | Heating & Cooling
Would like a manual for the rinnai energysaver 403FT we need to set our heater up so it goes on auto and how do we regulate the temperature and set time
The model number (403FT) has either been discontinued, changed or is incorrect. However, Model # RHE309FT closely matches the heater you described and has the timer and temperature features you are wanting to preset.
You may download and print the manual from the link below for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/CI_Energysaver_RHFE309_559FT.pdf
Hope this helps you and thanks for choosing FixYa. Cheers
Aug 15, 2011 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
I need to know more about "Countdown - Auto -
Open following link to identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
59377 manual
http://waterheatertimer.org/pdf/Woods-59377.pdf
Auto: timer must be set in AUTO for programming to work
The word AUTO is printed on timer face.
Small black triangle will display above the word AUTO when timer is in AUTO
Countdown is feature that lets you set timer ON for set amount of time, and when time expires, timer turns OFF.
Manual button.
I have not tested this specific timer.
Simply plug lamp into timer, and then push manual button to explore feature.
Watch what symbols display, and watch what lamp does.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 08, 2011 | Woods Industries 59377 Indoor Digital...
I have set the times for the heating to come on and put it to auto but it doesnt seem to come on at the times i've set it at??
If the Procom Model number you referenced is correct, this heater does not have a automatic timing feature to turn the heater On and Off. However, it does have a built-in thermostat control, that turns the heater's burner on, once the room/area drops below the temperature/comfort level you have set it for.
Conversely, it turns the burner Off once it reaches and holds the temperature/comfort level for 5 minutes or more, it turns the burner OFF, again. Keep in mind, because this is a built-in thermostat, it's reading the air temperature closest to the heater.
If the thermostat feature is what you're having a problem with, it may be that the sensor bulb has failed (assuming it's not turning ON & OFF automatically). However, this is a fairly rare failure. Unless, the heater is very old or hasn't been cleaned and serviced annually.
Another situation would be that the Control Knob has been left in the PILOT position, rather then the ON position. If that is the case, the heater will not turn ON, period.
Right now, your Owners Manual is your best source of information on the correct operation of the heater, as well as it's Trouble Shooting Guide.
If you have misplaced the Owners Manual, here's a printable link to it. Just locate the Model Number of your heater, ML300TB and click on the icon to the left of it.
http://www.usaprocom.com/manuals.php
Hope this helps you solve your problem.
Mar 03, 2011 | Procom ML300TBA Heater
How to make auto clean work?
The cleaning feature only cleans the igniter. This can happen automatically by just setting the clock. Clock button in Set position, set current time, button to Normal. The cleaning will happen at 2AM each morning.
Good luck,
Tom Hawkins
May 23, 2009 | Rinnai Toyostove Direct Vent Heater:...
Fan keeps running.
Some programmable thermostats have a circulate feature. This feature will allow your fan to run approx. 20 minutes per hour. This will insure better circulation, a better balanced temperature throughout the home & better air quality do to more air filtration. Read your thermostat manual to see if your thermostat has this feature and how to turn it off if needed. Another possibility would be on an older furnace with a fan limit control. If the temperature settings are set to low on the fan limit (or if the control is malfunctioning) you could experience a fan that runs a lot even if the thermostat is off.
Apr 10, 2009 | Honeywell Electronic Programmable...
My hot tub won't turn off. I turn the pool on and
check the owners manual. I believe your are experiencing the auto set feature, default perhaps and see if there is a setting to change the auto switching. The older models used to do that all the time.
Feb 19, 2009 | Jandy AQUALINK RS TELELINK KIT
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Using a thermal pot
I also bought the thermal carafe; before I could hack the warming plate, my wife set the "Auto Off" feature to 1 minute, which shuts off the carafe heater. The settings are preserved unless you lose power for an extended period.
The warmer does still warm through the brewing cycle but it doesn't overheat the carafe (IMO.) Hope this helps.
May 29, 2008 | Cuisinart DCC-1200 Coffee Maker
Dryers Logo
Top Dryers Experts
