Question about Whirlpool duet Washing Machines
My whirlpool duet washing is locked and will not unlock, and is showing a 1H code. Don't know what do with it. Any idea's as to what this code means? I have researched online and have thus far found 0 information on this code.
    Sergeant:
    Champion:
  • 257 Answers
There is no such error code on this unit. This could be F/H code for not having water go into machine. May you check your water source is coming through both as hot and cold water, do they were reversed, do you hear any humming noise from the back at the unit. Do the following steps to check.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
Posted on Oct 22, 2013
SOURCE: WHirlpool duet washer is stuck on "controls locked"
we ended up holding the drain/spin button for a period of 15 or so seconds and the issue resolved.
Posted on Aug 10, 2008
SOURCE: unlock control lock in washing machine, whirlpool, duet
Hold control lock for 3 sec. It will make a sound and the door will unlock.
Posted on Mar 21, 2009
SOURCE: Whirlpool duet model #GHW9400PWO shows
I have read many posts for this problem and I have my own solution. I interface computers to real world aplications and when I saw the control board for this washer I was appalled at what I saw. The tiny relays on that control board are rated for 10 or 16 amps. These are fine if you are only driving small devices but they cannot take the startup currents and back EMF of solenoids and motors. I have tried filing the contacts and resoldering edge connectors all to fail to solve the problem. So, I replaced 2 relays involved in the most critical operations. One was the small relay (K4) that activates the door lock/unlock solenoids. BUT instead of simply replacing the relay, I rewired the harness and added an industrial relay to do the heavy work of actuating the solenoids. I also replaced the main relay (K6). This relay is what the entire machine uses for all motors, solenoids and other relays depend on to operate. Here again, I diverted where the power goes to. The power that normally passes through K6 is now just used to operate an industrial rated relay.
I used original relays for the control board due to the fact that the electronics on that board were intended to only operate tiny relays. I simply diverted the power to drive larger relays. This was no easy task and it is not to be performed by anyone other than an expert in this field. I have a number of photographs and I am willing to share them with anyone who wishes to see what I did.
I would bet that very few of these control boards have actuall gone bad. Only the relay contacts have been slightly scorched to the point of intermittent reliability.
Posted on Apr 03, 2009
SOURCE: Whirlpool Duet Sport Error Codes?
My machine had the F21 code and the inlet to the pump was blocked with change, bobby pins, small rocks, pieces of fuzz and clothing. Removed the front cover of the mahine and removed the cap on the front side of the pump and cleaned this trap area out. The pump motor quit humming and the machine worked like it is supposed to!
Thanks
Posted on Sep 09, 2009
Jahn27
  • 1554 Answers
SOURCE: What does code F70 and F71 mean on my whirlpool duet?
Error code F70 means no communication is detected from the Central Control Unit (CCU) to the User Interface while F71 is the reverse; no communication detected from the User Interface to the Central Control Unit (CCU). This could simply mean a loose or poor connection between the two communicating boards.
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the three screws attaching the top panel to the rear of the washer then slide the panel rearward and lift it off the washer.
Disconnect the User Interface ribbon connector from the left side of the Central Control Unit (CCU) and clean the connector and terminals thoroughly. Reseat the connector several times to ensure a good connection between the Central Control Unit (CCU) and the User Interface.
It is highly recommended to clean and reseat every wiring harness connector from the Central Control Unit (CCU) to prevent the same problem in the near future.
Reconnect every wiring harness to the CCU and make sure all connectors are firmly seated. Slide the top panel back into position and secure it to the rear of the washer with the screws previously removed.
Let us know if the problem persists for further assistance. We will be happy to resolve your problem.
Posted on Mar 19, 2010
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/dU error code on...
The F/dU is shown on the display due to Door Unlock Error in the washing machine.
In this problem check the Door Lock in the washing machine. Either the door is getting blocked or not getting locked or the door latch assembly is got cracked.it needs to be checked and replaced.
This will help. Good Luck.
on Mar 11, 2010 | Washing Machines
Whirlpool duet ghw9200lw front load washer will not start cycle
Check the door interlock on the washing machine. If it's faulty, the machine won't start its cycle. This page will give you an idea of what interlocks look like.
Door Interlocks
Feb 20, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer is ona locked code
if you don't remember the code take it to a dealer that makes it and see if they can get it unlocked or change the code on the computer
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unlock control lock in washing machine, whirlpool, duet
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
203 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
