Question about Dishwashers
Fisher paykel nautilus
REset light flashing when start button is pressed. Prog.stuck on rinse.How do I reset??
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Hold button for 10 seconds.
otherwise >> service agent
Posted on Oct 18, 2013
4 Suggested Answers
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Dishdrawer beeping constantly
leave it unpluged to stop for now, the machine has detected a leak and is constantly running hte pumps within the drawers to try to remove any water.. problrm is the water detector is in bottom under the lower drawer and htere is no pump to remove that water ..canbge a fickle machine as far as leaks are concerned, but the easy reason is usually misloading of the drawer itself, was an item put in that was too tall , preventing the lid from coming down and sealing off drawer causing water to overflow down the side??? there should be(so logn as no previous repairmen have taken it) a tech/trubleshooing guide taped to teh back wall behind the lower drawer, which is easily removed by unlocking hte hinges on either side of the front of drawer, explained in your manual
Posted on Nov 03, 2008
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Need to do a reset on a gw612 after changing the cold valve
There is no reset for these.
If you are getting error code 48,49,50
your motor controller board is faulty.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel Nautilus Dishwasher wont advance to take water in .
The problem could be with flood switch at base of dishwasher. Press the float to check if it springs back. Otherwise switch under it is faulty.
Jan 19, 2013 | Fisher and Paykel Dishwashers
Have had a Fisher and Paykel 6.5Kg Washing Machine for about 5 Years. After about 30 Seconds two lights start flashing on the Dashboard.They are Orange Lights one on the Long Wash and the other between the...
Yes it can but I need better info. The lights are the error code. I need to know exactly which lights are on, Count from the left and tell me what number lights are on out of the 8 lights along the top row when it beeps and before you press any buttons.
Nov 05, 2017 | Fisher and Paykel Washing Machines
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Sep 08, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
How do i put intuitive eco on to just spin clothes not a whole wash cycle
press power button press up button 2 times on option button to "wash advance" press adjust button to which ever rinse cycle youd like to use. press start.
Jun 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel dish draw
Turn the power off to your dishwasher for about 30 seconds by flipping off the circuit breaker in your home's breaker box. When you turn the breaker back on it will have reset the dishwasher and should begin working just fine.
Aug 24, 2008 | Dishwashers
Manual reset
take note of whoch lights are flashing on back panel, generally i ask cust to take a index card or similar size paper and placedit under your light indicators(wash--rinse----spin)think thers 7 or so lights .noting which ones are flashing when shuts down, will determine problem for you,under main console(2 screws across back) is a tech sheet to help you out
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
