Question about Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge Freezer
Compressor stopped working and it has a three pin electrical connection on the 'black tub'. What are these individual pins, i.e positive, negative,?. I want to understand how to wire it up directly without the relay etc - to see if it works. Thanks
  • 363 Answers
I think you'll find the relay is there to start the pump by switching the mains to the shorter winding in the motor, hence three terminals. Once the pump is running the relay "drops out" and the motor runs on the longer winding. Check with a multimeter if the windings are intact. There's no Positive and Negative for AC operated devices i.e. it doesn't matter which way around the power (live and neutral or Hot and Cold) goes in but Earth or Ground MUST be correct. Dont kill yourself!!
Posted on Sep 26, 2007
SOURCE:
My bush BAFZ5585W just stopped working, it's not all that old and it's not the fuse, any ideas?
Hello Tracy;
My name is Peter. I am a retired field service refrigeration.
These units are nice, inexpensive and delicate.
There are not a lot of components to this unit.
1.) As a former service technician I have found the customer is not careful when defrosting. The manual states use a plastic spatula and a hair dryer. The refrigerant passes through the plates. Customers us hammers and screw drivers to remove the ice. The customer nicks the plates and the refrigerant leaks. Feel the plates. If you feel a oily clear substance you have a refrigerant leak. This repair will cost more than what you purchased the unit for.
2.) The Compressor & Overload relay. Unplug the unit. Remove the side panel. You will see the compressor and a box fixed to the compressor. The box is attached by wire clips. Using a flat head screw driver pop the clips off. There are 3 metal studs on the compressor. You will see a white piece with a 'V'. This is the overload. Using a flat head screw driver pry off the connectors including the white component. Inspect the component for burn marks. Shake the white component. If it rattles it is bad.
The compressor - You need a multi-meter to check the compressor. There are 3 pins on the compressor. Set the multi meter to the lowest setting on Ohms (The Omega Symbol). Put the two probe end together. You should get a reading of 1.0. Put the probe on two pins of the compressor. Record this reading. Ten the next set, record this reading and then the third set. There will be one high reading and two lower readings. If the two lower readings add up within reason to the high reading the compressor is good.
With the compressor and overload, sometimes you have to purchase both at a cost of $250.00. In this case you are better off to buy a new unit.
The temperature control T thermostat is difficult to check. If all of the previous component check out then this is your problem.
Peter, Baltimore, MD, USA
Oct 30, 2014 | Freezers
Freezer compressor
How is temperature controlled, refrigerant pressure? Thermostat? Does the top of the compressor get too hot to touch?
Aug 24, 2017 | Freezers
What is clixon
It is an overload protection device that cuts the power to the compressor if it draws too much current or overheats. Usually fitted close to the compressor body in a black box with the relay. Test by making sure you have continuity between the pins
May 04, 2012 | True 72 cu. ft. / 2039 liter Commercial...
L.comTrue model GDM-23 starts and stops(very short cycles10 sec. or so
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
May 15, 2011 | True 23 cu. ft. Commercial Freezer...
I had a flood in the basement where I keep my Frigidaire freezer, model FFU17FC5W3, which left 4 inches of water on the ground. The following day I drained the basement and dried it up and the freezer was...
Welcome to FixYa.
Likely just the start device, the compressor is a sealed unit so the water would not have affected it.
Here's what I'd suggest you try...
If you feel like you can trouble shoot further I`ve provided the following info to assist you or you may decide to call a professional appliance technician as I would suggest.
I don`t know the age of your fridge, but I should mention...
** Most of the manufacturers of fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.e.
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather thefactory replacemnet, double check with your model number.
Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Mar 18, 2011 | Frigidaire 17 cu. ft. / 481 liter Upright...
My DCF550W just stopped working. Yes - it is plugged in, and the breaker is not tripped! There is no response to dialing the temperatiure control to any position. It sure sounds like the overload protector...
Welcome to FixYa.
I suspect by your description the freezer either has a faulty overload protector as you mentioned (no there is no reset) or the compressor itself is seized.
** Most of the manufacturers of fridges/freezers have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
**First, Unplug the freezer**
Remove the panel at the back or side down at the bottom. This should gain you access to the compressor.
i.e.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather the factory replacemnet, double check with your model number.
Regards,
Macmarkus :)
Mar 02, 2011 | Danby 5.5 cu. ft. / 156 liter Chest...
My bottom freezer amana refrigerator is making a clicking noise. And my freezer is barely cold.
Refrigerator making clicking noise compressor not running.
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine.
Jan 29, 2011 | Amana Freezers
Need wire diagram how to install 3 N 1 start relay on a true t12f freezer
The two stripped black wires connect to power.
Black tabbed wire to common.
Red tabbed wire to run.
White tabbed wire to start.
Looking at pins on compressor, read like a clock. Common clockwise to Start clockwise to Run
Apr 29, 2010 | True 12 cu. ft. / 340 liter Commercial...
I have a Kenmore coldspot 16 cu ft chest freezer and it DIED on us last night. No sounds nothing. Any ideas on how to check anything would greatly be appreciated. I was told my compressor died.
It might have. Most likely you can start it again, but you will have to follow my instructions carefully. If you are willing, I'll tell you how to check it to see it it's bad and if not how to make it start again.
You will need a Ohm. meter and it will help if you know just a little about using it. If you do, gain access to the compressor. You will see where the wires go to it. The wires are connected to a piece or two that connects to your compressor. After unplugging your freezer, pull the parts off that are attached to the compressor. Now you will see three small metal pins sticking out of the compressor. Take your ohm meter, touch one lead from it to one of the pins and take the other lead and touch it to ground or somewhere on the copper tubing. If you have a reading, the compressor is grounded meaning it's bad. If yo have no reading. Take a lead and touch it to one of the pins while you are touching the other lead to another pin. It makes no difference which tow of the three your touching. If the compressor is good you should have a reading. Jot it down. Now move only one of the leads to the pin you have not touched yet. Jot that reading down if you have one. Now move the last lead you just moved and touch it back on the pin you started touching it to and move the other lead to the pin you just moved the other from. Jot that reading down. If the compressor is good, you first will have a reading each time you were to jot one down. Now look at you numbers you jotted down. The two smallest readings should add up to the largest reading if not exact it should be real close. If so, we can restart your compressor. You will need a Supco 3 in 1. You can get one from www.appliancepartsonline.com the part number is RCO410. It cost $21.95 plus shipping. The packaging will have the instructions on it. What you will do is gather all the parts that you pulled off the compressor. Cut them off. You should end up with only two wires. The 3 in 1 will have two Black wires that you will connect together with the supplied wire not. There will be three wires with ends on them coming off the 3 in 1 also. they will be White, Red and Black. Follow the color coded instructions on package. When you have completed these steps. Plug your freezer in. The compressor will start and run. The closer the numbers you added before where, most likely the longer the compressor will last.
Please rate solution.
Sep 08, 2009 | Kenmore Freezers
Kenmore freezer upright
The S terminal should read zero when you invert the relay. The M terminal should be zero at all times through the relay. If you follow the coil wires on the relay you will find they go from the line connection to the M terminal. M meaning main or run terminal. When current is drawn through the M terminal it pulls in the contact for start to the S terminal. When the compressor comes up to speed the current drops off and the start contact opens allowing the compressor to continue to run on the M terminal.
Sep 14, 2008 | Freezers
Engel Freezer 22 Qt. Fridge/Freezer Logo
139 people viewed this question
Top Engel Freezers Experts
Felizardo Erilla
Felizardo Erilla
AJMAL KHAN
ray gallant
ray gallant
Are you an Engel Freezer Expert? Answer questions, earn points and help others
