Question about Samsung Computers & Internet
Touchpad driver not work - Samsung Computers & Internet
    Problem Solver:
  • 7 Answers
Download the latest driver from Samsung's website specifically for your laptop. You'll need the serial number and/or service tag number from the underside.
Posted on Oct 17, 2013
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Touchpad not working
There's a tiny orange light near the upper left corner of the touchpad to the left of the touchpad. If that is lit, you may only have to tap the upper left hand corner of the touchpad a couple of times to get it to go out. and start the touchpad working.
Barring that, see if the synaptics driver is installed. Go to "Control Panel," change the "view" in the upper right hand corner to "large icons," and see if "Synaptics Touchpad V8.1" is listed.
If not, go to "Control Panel," locate device manager and click (with a usb mouse) "mice and other pointing devices," click "Synaptics PS/2 Port Touchpad," and check to see if it says, "device is working properly." If not or if it still doesn't work, click the driver tab, and click "update driver."
Dec 08, 2012 | HP elitebook 8760w
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
Accer emachine e725 touchpad mouse not working............
Plug in a USB mouse and then try to download the Acer driver for your touchpad here: http://support.emachines.com/em/driver/index.html
If you install the newest driver off of the Emachines website, and the touchpad still doesn't work, then it is possible that the touchpad has gone bad.
Nov 15, 2011 | Computers & Internet
My touchpad won't work on a compaq presario CO50, button is on, but on working?
Try a restart if that doesn't work, connect a usb mouse and go to the device manager and see if the drivers for the touchpad are installed.
If they aren't, go to http://www.hp.com and input your model number into the search box, there will be a place to download the touchpad drivers. Install those and your touchpad should be working.
Mar 07, 2011 | Compaq (153515-001) Touch Pad
Acer laptop Aspire 5732Z touchpad not working...have been using mouse all along and touchpad was working now it isnt...did the fn f7 no help...checked the device manager all seems fine...tried to update...
I have the solution...
u see where the switch on button is ? next to it there are two buttons ...ones for stopping internet connection ...thats the one on the right. the one on the left is the one for locking the touchpad
if that button has a orange light blinking on it it means its locked ..
so just push the button and see if it works :) .
Jul 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
My touchpad scroll not working
Problem with touchpad driver. Download and install latest driver from the manufacture's website (synaptics, alps...) if you know the driver name.
Else try the software DriverMAX
(downloadable at http://www.innovative-sol.com/drivermax/)
Im using DriverMAX. Its a good software that can automatically detect versions of drivers in our computer and update them if you have internet connection.
Also ensure that in startup programs (RUN>MSCONFIG) the touchpad driver entry is enabled!!
Oct 26, 2009 | BenQ Joybook 5100U Notebook
Touchpad tapping is not working
You need to download and re-install touchpad drivers to get the tapping function working.
You can download the touchpad drivers from the link below:
http://blogntech.com/download-lenovo-ideapad-s10-xp-driver.html
May 09, 2009 | Lenovo IdeaPad S10-1208U Netbook
The touchpad got locked
u can try this all u can do is just go to this website and click on driver detective scan now and then click on the download now and then restart ur computer and then the touchpad should work and still if it doesnt work then uninstall and resintall the touchpad driver and the synaptic drivers and restart the computer and still if it doesnt work replace the touchpad from dell...the website is http://www.drivershq.com/Drivers/VistaDevices/Dell-Input-Dell-Touchpad-Pointing-Stick-Driver/13926/Drivers.aspx ................... thanks
Jan 22, 2009 | Dell XPS M1530 Laptop
Dell touchpad problem
Try to reinstall the touchpad driver.
Get it from this link.
Dec 09, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
14 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
