Question about Danby DWC610BL Wine Cooler
Wine fridge is freezing - Danby DWC610BL Wine Cooler
Where can we get info relating to wine fridges?
use google and enter " wine fridges "
Nov 30, 2016 | Furniture
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
Mini fridge
Check where the thermostat probe is situated, it has to sit up against the evaporator to tell the thermo it's cold enough & to shut off.
Dec 02, 2013 | Viking VUWC140 Wine Cooler
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Jul 31, 2012 | Furniture
I just bought a used (but never installed) wf 1061 (freezer with a wine fridge). the unit and dsidplay lights up as normal...but i don't hear the compressor starting...can it be in demo mode?...
Try this also:
Super freeze 5 seconds set desired temp press super frees briefly again then adjust the wine cooler temp press super freeze again briefly, Next press menu and select normal. Then press menu again. To exit press super freeze again until it no longer blinks.
Kelly
Aug 28, 2011 | Freezers
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Everything is freezing in our refrigerator even
Your thermostat has failed and requires replacement. If the fridge is very old you could use a mains interupter device that has a temperature sensor that is placed in the fridge. There are several hobby kits for such devices usually used for converting old fridges for wine storage.
Sep 29, 2009 | Frigidaire Refrigerators
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Nov 27, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Danby DWC610BL Wine Cooler Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
