Question about Duke Ovens
Oven not staying at set temp. reaches temp just wont stay
  • 139 Answers
SOURCE: Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Posted on Aug 28, 2008
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
SolutionGuy
  • 331 Answers
SOURCE: GE JKP26G Electric Oven Doesn't Maintain Temperature
Diagnosis= failed thermister (temp probe inside the oven cavity) The part number is WB23X5340 and it lists for ~$72.00 at your local appliance parts place.
Bad news is that you have to pull the oven out of the wall to do this repair.
Good news is that it's not difficult to do.
TURN THE POWER OFF AT THE BREAKER BEFORE YOU PROCEED! Otherwise you'd look like this...
Ready? OK!
All you need is;
1.) Phillips screwdriver
2.) 1/4" socket/nutdriver
3.) Ratchet if you don't have a nut driver
4.) 36 quart Igloo ice cooler (like what you'd take to the lake or the beach)
5.) Sturdy wire (smaller than a coat hanger, preferably)
6.) Flashlight
Did I mention TURN THE POWER OFF AT THE BREAKER BOX?
Now we're ready for surgery.
Open the oven door and look where the oven meets the wood. You'll see a couple of screws there... remove them. Now the oven is ready to pull.
Place your Igloo cooler under the oven. Slowly pull the oven from the cavity until you have it out and sitting on the cooler. (don't sweat it... the oven is light. maybe 75 pounds or so.)
Now that you have it out, open the oven door and remove the oven racks. Look inside (may need a flashlight) and locate the temp probe, there are 2 screws holding it in place. Remove those 2 screws and set them inside the oven cavity, you'll need them soon.
Now go to the back of the oven (slide it if necessary) and remove the back panel. (*Here's a tip... some of these GE units? All you have to do is remove one screw to access the temp probe, so look carefully... don't go nuts here. Sometimes the whole panel/panels DON'T have to come off)
You'll see the temp probe wires... they are 2 small white thermally insulated wires coming from the cavity to the wire harness in the back. Disconnect this harness and pull the old probe out from the front of the oven cavity.
OK... now to get the new probe installed... See that plastic thing on the end of the new probe? It's a pain to get through the cavity where you'll be plugging it into. It's best to have help. but it can be done alone (I've never had help, it's just harder)
Take the sturdy wire (from the tools list) and make a small hook at the end of it. Poke it through the hole that the old probe was stuck through. Now hook your new probe into the hook. Now go to the rear of the oven and gently (did I say gently?) pull it through to the back of the oven.
Now that you have it through, connect it to the harness. Now all you have to do is reinstall the rear panel/s and the oven. No biggy. Just take care not to scratch your wood trim... line it up before lifting and installing.
All in all about an hour's worth of work. I know it sounds like alot more but I could have done this in less time than it took me to type it.
Congrat's on your first major oven fix! Let us know how it turned out.
Posted on Mar 17, 2009
  • 12 Answers
SOURCE: oven not reaching correct temp
It isn't a design flaw. It is an air pressure switch. Main fan not running OR oven is dirty and the tube to the air pressure switch is clogged. Dirty ovens aren't a design flaw. I saw it once a week. Five minutes clearing the tube and you back in business. Hope this helps.
Posted on May 25, 2009
  • 491 Answers
SOURCE: The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Posted on Nov 09, 2009
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 | Ovens
We have an electrolux E30EW85GPSS double oven. The lower oven appears to work properly. However, the upper oven will bring itself up to the set temperature but after reaching it, does not stay on and...
Hi
This means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control board however, as the issue is only with upper oven it is most likely that the temperature sensor is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Electrolux E30EW85GSS Oven
Upper element stays on
Check out this tip... it willhelp you to understand what is happening..
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Mar 23, 2010 | Ovens
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
i did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Jul 14, 2009 | Maytag Ovens
Kenmore self cleaning oven model 790.9520 : element stays on
sounds like it was in the preheat mode the cent to the cook mode so you can cook
Dec 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Frigidaire Oven Problem
please post the model Number here..so i can look it up but just off hand there maybe an oven sensor (thermistor) problem this in inside the oven and tells the electronic ctrl board what the actual temp is in the oven it says 135 beacause it will until the temp reachs that after that as the temp goes up it will read 140 150 160 .. and so on until it reachs the set temp .. Is the oven getting hot and are there any fault codes coming up??
Jan 28, 2008 | Ovens
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Oven won't stay hot
http://www.lieffcabraser.com/profileovencomplaints.htm
the digital control for the JPT-18 and customer are trying to have GE replace them. It is called the F7 error
Click the link above to see more about the problem. GE wants the customer to pay for the error. Hope this helps. JT
Oct 23, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
22 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a Duke Oven Expert? Answer questions, earn points and help others
