Question about Sony BRAVIA Televison & Video
I have sony bravia kdl55bx520 and onkyo arv401 amp and I want to connect external audio and speakers for theatre sound.
  • 39 Answers
You should be able to connect the amp to the TV using RCA cables. Below is the Amp's owners manual.
http://www.manualslib.com/manual/302331/Onkyo-A-Rv401.html?page=4#manual
Posted on Oct 17, 2013
Strattrpt
  • 159 Answers
SOURCE: i have external speakers /
I do not want to sound patronizing, but I have no idea how much you know about wiring ... so I'm probably going to over-explain everything. Hopefully it won't read like stereo instructions ... ha ha ha
Depending on your TV, theremight be a door covering the wire access .. or there might be audio outputs on the front of your TV ... but these are more likely to be inputs for game consoles and other things. You should have a red and a white jack in the back of your TV marked "Audio Out" ... those are left and right audio outputs from your TV. Use RCA cables from Radio Shack or wherever and connect that to your amp left and right audio inputs -- the RCA jacks should be the same color as the wire connecting them, which makes it easier to trace wires later. Generally, the amp should have a red and a white RCA jack as well .. make sure they match your wires , too ... or you'll end up hearing things in reverse. You should find sterio wire inputs on the back of your amp -- if your speakers have the wire connected, set them up and then plug them into the appropriate jacks. There shoud be some sort of lever on the side of each of thee jacks, push it open and insert the wires. Some of these are spring-loaded so you might have to keep your finger on it to hold it open. Just put a bare cord from the speaker into it, and make sure the lever closes again, securing the wire. Your amp should have the left and right speaker outputs, subwoffer output, and everything labeled, but you'll probably need a lot of light on it to see it (usually it is just a recessed or relief letter L and R for the left and right speakers.
I am not exactly well off, so most of the electronics I have are a bit old. You might only have a different audio output from your television, in which case I would recommend speaking with someone at Radio Shack -- they tend to know a lot about wiring electronics together (more than at Best Buy or other big-box stores) or if you don't have one of those around, find a local electronics store, or a pawn shop ... people who work in these types of places usually enjoy the challenge of putting a round plug into a square jack.
Posted on May 24, 2011
  • 37 Answers
SOURCE: Connect external PC speakers. Don't want home theatre system.
the only way this will work is if you have a headohone jack on your tv.
Posted on Jul 12, 2009
Skizziks
  • 43 Answers
SOURCE: No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Posted on Aug 31, 2009
  • 541 Answers
SOURCE: connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Posted on Oct 24, 2009
Testimonial: "Thanks for your help. George"
SOURCE: I have a new Sony
Well, one of the solutions would be a universal remote control.
The way amplifiers usually work is such that the volume needs to be adjusted on the amplifier and not the source (TV in your case).
If you can give me more information on the model of your amp I might be able to prove die you with another solution.
Posted on Mar 05, 2011
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
My onkyo tx-ds575x lost power in a storm and now I get no audio from it. The sony bravia tv has sound but the onkyo won't send it to the speakers.
Please reset Onkyo receiver that will solve noisy sound problem, to reset the receiver, press and hold Video-1 button on unit and press Speaker-A button. Display will show *Clear* that means receiver has been restore on default settings, turn it On and check sound.
Hope this will help.
Thanks.
Apr 06, 2011 | Onkyo Audio Players & Recorders
I have a new Sony Bravia LCD TV 40" EX500. That I need to hook external speakers to thru an ONKYO amp. The amp has optical and coaxial Audio in but NOT HDMI. I have connected the optical Audio...
Feb 17, 2011 | Televison & Video
Hi I have the Sony DAV-HDX285 home theatre system and I'm trying to get it to work with my Vizio 47" HD tv. I go thru the speaker setup with the dvd supplied and all speakers are working tthu the home...
I assume you mean the TV sound only comes out of the TV. THAT would involve internal audio controls at the TV.
Why don't you just connect the TV-related audio directly from each source to the DAV instead of through the TV, which adds NOTHING to the sound quality and may even degrade or limit it.
Aug 17, 2010 | Sony Bravia DAVHDX285 Theater System
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sound problem
check the menu on the tv to see if the speakers are set to off
I think if you connect it to external amp the tv's speakers must be shut off beofre it will activate the line out audio
Nov 05, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Tv speakers
Sounds like you have a home theatre system, and you need to run rca cables from audio out of the tv to audio in on the amp, and turn the speakers off in the tv menu and set audio out to fixed or turn tv volume up all the way to get enough audio siginal.
Feb 24, 2008 | Sony BRAVIA KDL-40V3000 Television
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
