Question about Garden
I need to do an overall engine service. And I want to to toque my engine but I do not know how to use a torque wrench.
  • 43 Answers
Do you know the torque specs for the bolts? Do you have access to a torque wrench?
Posted on Oct 18, 2013
All toque specification
which engine
if we know the engine
that engines repair manual will give you all the torques
from mains ,conrods ,cams to rocker cover
May 18, 2016 | Cars & Trucks
Tip
Proper use of a torque wrench
A torque wrench is a powerful yet sensitive piece of equipment. When used correctly it can mean the difference between a job well done and job gone wrong.
Proper torquing is easy as long as you remember a few simple rules. One, never use a toque wrench to loosen bolts. Two, never use any object to hit or pry on a torque wrench, These things will result in damage and or improper readings.
The proper method for torquing is to be ready to apply the correct amount of force. Anything over 60-70 lbs may be hard for some people. Get assistance if needed. Not applying the correct pressure (stopping mid pull) may bind the wrench. Use a steady pull until the click is heard or felt, never tug or bounce the wrench.
Following these steps will help insure a proper assembly no matter what it is. Work safe and work smart. Happy building
on Jun 10, 2010 | Hand Tools
Toque settings for a Nissan Terrano II R20 SE 2.7tdi
go google --type in torque settings for ---your engine-- and there will be pages of settings and the correct sequence to do the process all in pdf form
Aug 08, 2015 | Nissan Cars & Trucks
Remove electric clutch
Removal not too hard if you have an impact wrench. It is the reinstalling that will be harder as you got prevent the crankshaft from turning. Some clutches have a 1-3/8" double flat that hold and torque the center bolt to 55 ft-lbs; others require block the flywheel movement to toque the center bolt.
May 24, 2015 | Garden
I need to know the torque wrench settings for a infiniti g35 coupe? when i change the spark plugs i noticed one of the seals is broken and spark plug is fill with oil. i want to remove all the seal
the spark plug tubes seals are part of the valve cover gasket most valve covers toque to 80-105 INCH pounds and ther spark plugs on a COLD head are 15-21 FOOT lbs HOT are 15 FOOT lbs.
Jan 12, 2015 | 2005 Infiniti G35 Coupe
How to access cylinder head on husqvarna rider?
?? Why do you need the head torque? Was this an overhaul? Consult the factory service manual. If not possible, torque setting depend on several factors, .. application, (cyl. head), engine mounts, etc.. this is mainly determined by bolt and nut size and relative to the application. There are charts that recommend toque values relative to bolt sizes. I can't tell you because I don't know what size the bolts are! Hope this helps!! Goolge it!
Aug 17, 2014 | Husqvarna Garden
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Mar 28, 2011 | Ingersoll Rand Air Tools & Compressors
Chain torque settings
I don' t have a torque wrench either, and I adjust my chain on the road, with a big adjustable, just tighten it up and go. Ducati S4, Hope this helps.
Apr 14, 2010 | 1987 kawasaki GPZ 500 S - GPX 500 R
Torque specs for spark plugs
You don't need to torque spark plugs. Just make them tight. I usually add never-seize on the threads but I have never once torqued spark plugs.
Jan 15, 2010 | 2004 GMC Envoy
Torquing the wheels
105 foot-pounds.
Charlie
Aug 29, 2009 | 2004 Mini Cooper
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
