Question about Toro TimeCutter SS5000 zero turn mower
When starting just hear loud grinding and clicking noise motor will hardly turn over... battery is charged
2 Suggested Answers
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
Motor does not seem to work. sensor light does not come on. you hear a noise indicating the batteries are working
If you are hearing a loud "Clicking" noise when you turn the key it usually means the battery has some power but not enough cranking amps to start the car. Get a battery charger on it or take it somewhere and have the battery tested.
Jan 18, 2016 | Cars & Trucks
Replaced starter,battery,and altenator...still wont start,it makes a loud grinding noise
The noise u hear is the starter gri?ding against the flywheel motor most likely seized
Oct 05, 2015 | 2002 Dodge Ram Pickup 1500
My 2002 Kia sedona van was going down highway , it made a grinding sound , motor died , now starter just clicks, motor won't turn over : whats could be the problem ?
Starter clicking, not enough power to turn motor over. Check the battery, make sure charge is full. If it is, your starter is shot, replace it
Apr 16, 2014 | 2002 Kia Sedona
Loud noise sounds like fan
It's the cold air injection fan motor your hearing yes it is normal that you hear it. As for grinding noise your going to have to look under the car to see if anything is rubbing.
Feb 04, 2014 | Volkswagen Passat Cars & Trucks
Bike starts to turn over but then stops and you hear this rapid clicking noise. Prior to this it would start but sometimes hear a fairly loud crunch noise like starter or something before it kicked over....
Its probably either a low charge on your battery or the battery cables don't have a good connection. If the battery's more than a few years old I'd just replace it because it will likely continue losing charge now that its already been drained once.
Aug 31, 2011 | Harley Davidson FLHRCI Road King Classic...
Loud click when I press the start switch 1989 LS650 Savage
The loud click kinda indicates the starter is the problem. A fainter click would implicate the starter relay as the failing component.
Since I can't hear the noise, I would say first check the starter for 12 volts from hot to ground when the ignition is in start position. If you get 12 volts upon this test, then it's most likely the starter relay.
Then check the relay for continuity with starter disconnected from it and the ignition in start position. To find these components, just trace the red cable from the battery.
More info, let me know.
Charlie
P.S. The lights flicker because the battery voltage is dropping when the starter tries to turn over.
Aug 29, 2009 | 1996 Suzuki LS 650 Savage
98 ford windstar has clicking noise under dash and won't start
The clicking noise is most likly the starter solinoid cycling in and out. This is due to low battery voltage. charge the battery, then have the battery and charging system tested. Some auto supply stores will do this for free for you in the hopes of selling parts
good luck
Feb 09, 2009 | 2000 Ford Windstar
1998 pontiac transport montana starting problems
It could be the starting motor is faulty or was not installed correctly, particularly if you are finding it turns over the engine slower than it should (dragging and dragging down the battery voltage). When starting the car, the teeth must mesh properly with the ring gear or all sorts of strange things will eventually happen. Alignment is controlled by shims on the mounting bolts and if they are the wrong ones or missing, also usually bad news.
Jun 25, 2017 | 1998 Pontiac Trans
Toro TimeCutter SS5000 zero turn mower Logo
109 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
