SOURCE: How to reboot printer Xerox
How to reboot printer Xerox DocuPrint C4350 error code : 009-383
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
SOURCE: Replace Fuser Reset
For the MFC 8860, I turned off the printer. I help down menu. I turned on the computer. It entered Maintenance mode. I typed in 88 (Parts Replacement.) I scrolled to the fuser, clicked ok. Then, I turned off the printer. When I turned the printer on, it said that I needed to replace my laser. I then turned the printer off, help down menu, turned the printer on, typed in 88 at the maintenance menu (parts replacement), scrolled down to laser, and hit ok. I then turned the printer on and off, and poof, now it works. I find it quite unscrupulous that I had a replace PF Kit1, replace Fuser, and replace laser messages all within one hour...
SOURCE: Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
SOURCE: Reset maintenance counter
To reset the Maintenance counter yiu need to go into Config Mode.
Power on the printer while holding the 2 & the 6 button.
You will see the maintenence counter and can reset it from there.
