Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
In the main power flechuvation the i.c will brocken .so pls send the i.c number of DC18RA battery charger
5 Suggested Answers
  • 165 Answers
SOURCE: Brand new Makita DC18RA charger wont charge the batteries.
Return to store for replacement.
Posted on Feb 27, 2010
trig_noz
SOURCE: Hi, My Makita DC18RA won't charge anything it just
none of these answers help. you cant return old chargers to the store, and the poster said his battery charged on a different charger. i have the same problem with 2 makita battery chargers and need to know if there is a part inside the charger that can be replaced.
Posted on Aug 25, 2012
SOURCE: my dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
Posted on Nov 26, 2012
djromeo69101031
  • 17 Answers
SOURCE: DC18RA battery charger i.c number
call Makita...they've always been real good about warranty'ing their products... (they'll probably just send you a new one on your word?!) it's definitely doesn't hurt to ask...?!
Posted on May 08, 2014
110v been pluged into 240v so does not work.solutions
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 11, 2014 | Makita DC18RA Rapid Battery Charger For...
May 08, 2014 | Makita DC18RA Rapid Battery Charger For...
DC18RA battery loader is not working anymore.
Makita chargers are designed to check a battery before charging them. If both the red and green lights are flashing after you put a battery on the charger, it is reading a problem with the battery and will not charge it. It could be a bad cell, a problem with the circuit board, etc. but as long as it reads the problem it will not charge the battery.
Jan 04, 2013 | Makita DC18RA Rapid Battery Charger For...
Where can I get a schematic diagram of Makita DC18RA Charger?
my battery charger ic broken for a.c power flechuvation so iam not seeing that i.c number so i will ask you model DC18RA
Feb 14, 2011 | Makita DC18RA Rapid Battery Charger For...
I bougth reciprocating saw, model BJR 182Z and circle saw, BSS611Z while I was in the U.S.A.These tools use the 18 volt LXT Lithium-Ion battery BL 1830. I also bought this battery.However I am going to use...
Why can't you buy the 230 volt DC18RA charger in europe (amazon.europe country) and use it. I had the same issue yet i burned out the fuse in the 110 volt DC18RA charger because i plugged it into the wall just using an adaptor. Lesson learned. Therefore, my first solution was that i bought a converter from 220V-to 110 Volt. This showed me that my charger was done. So instead of getting another 110 volt charger sent here to Europe from Canada, I returned the converter and have on order a 230 volt input DC18RA charger from amazon.de which has the same 7.2-18V output. I have been told this will work yet the fear, and I don't know why, is that it will burn out the batteries in a year or so. It is difficult getting specific information from Makita, but I hope it all works out. Best of Luck for you
Dec 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Hi, My Makita DC18RA won't charge anything it just flashers the red and green light simultaneously it is not the batteries because I can charge them fine using anther charger. What is wrong with the...
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Have a DC18RA fast charger brand new from the USA. TRIED to charge a battery for the first time , unit plugged in with a universal adaptor for the power point. as soon as i put the power on it blew the...
Hey Chris
sorry to read of your unpleasant experience.
I assume you are in a 220-240AC net.
Anyway, this charger will not work well if at all with a universal charger because of the high power it needs.
You can use a transformer which cost a lot for this spec, modify the unit or buy a unit for 220VAC.
If you are into modding it, have a look at this page assuming you have model DC18RA T , P/N: 630516A7
If you are lucky only the fuse and probably a capacitor and varistor blew up, you should check this.
Good luck
Avi
Mar 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
54 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
