Question about Maytag MVWX700XL Top Load Washer MVWX700XL
I have a Maytag MVWX700XL i was washing laundry, it filled with water and now it wont do anything but light up and lock door
Check the the water pressure switch
Posted on Oct 17, 2013
duby1990
  • 367 Answers
SOURCE: MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Posted on Nov 21, 2008
catriver
  • 878 Answers
SOURCE: Washer
Suem...Check your lid switch. With the lid closed, push on the atuator with a small screw driver...see if it starts agitating. Revised switch kit part number is 12001908. Catriver..post back.
Posted on Jan 27, 2007
  • 1294 Answers
SOURCE: Maytag Neptune MAH4000AWW
Try some WD40 on the door lock.
Posted on Jan 28, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
wpcustomer
  • 345 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    Maytag neptune washer code FL and DO
    FL means the door failed to lock
    DO
    means washer door is sensed as being open.
    Aug 19, 2016 | Maytag Washing Machines
    I have a maytag mtw5770tq0 I just put a new timer on water will fill but will not start washing thanks Dennis
    This could be a lid or door interlock failure depending upon the type of washing machine.
    Jan 10, 2015 | Maytag Washing Machines
    I have a new 700XL and it seems that water is leaking from inside the machine. Anyone have a similar issue?
    SOUND LIKE A SEAL MIGHT BE BLOWN. MUST EXAMINE THE MACHINE TO LOCATE THE AREA OF LEAK UNDER THE SHEET METAL COVER.
    Oct 07, 2012 | Maytag MVWX700XL Top Load Washer MVWX700XL
    My laundry fills up but wont start, what could it be ? P. Lucca
    Hi
    When the washer fills however, won't start the issue is either a bad motor or the door lock switch assembly. However, after reading what you have written it seems that the issue is with the motor that is bad and should be replaced. Hope this helps...please post back for further assistance.
    Daniel
    Jun 27, 2011 | Maytag Washing Machines
    My machine is showing the code FL machine has problems locking. How do I resolve this problem
    Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
    The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
    Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
    1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
    3.Replace responsible component.
    Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag a112 manual on how to add bleach AND fabric softener
    Hi
    Choosing Your Detergent, Bleach, and Fabric Softener..
    Learn what the different items you need to wash your laundry.
    Liquid Laundry Detergent and Fabric Softeners
    When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
    You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
    The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
    Powdered Laundry Detergent
    You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
    Bleach
    When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
    Setting Your Washing Machine
    Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
    Regular Washing Cycle
    The regular cycle is used for the following types of clothes and other apparel:
    • Jeans
    • Towels
    • Blankets
    • Sheets
    • Quilts
    • Bedspreads
    The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
    1Permanent Press Washing Cycle
    The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
    Such as:
    • Blouses
    • Shirts
    • T-shirts
    • Under garments. This would be your unmentionables and socks.
    • Jackets
    • Sheets
    • Baby Clothing
    The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
    Delicate Washing Cycle
    The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
    The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
    Soak Washing Cycle
    The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
    You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
    Washing Your Laundry
    Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
    Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
    If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
    Thanks for contacting fixya.com
    Nov 13, 2009 | Maytag Washing Machines
    Washer filled with water to began wash; once closed....nothing- wash cycle did not contuine - standing water remains. will not spin or perform any other actions. has stop working entirely
    That sounds like a faulty door switch. This can be tested by a technician bridging the door switch contacts. Check also that the door lock is not stuck inside using a pencil or a small screwdriver, be careful not to damage door lock.
    If the door lock was not the problem, then check the water level floater , and also ensure that hot water is filling properly, otherwise the thermostat wont detect right temperature and cycle will stop.
    More likely you have a problem with the door lock switch.
    Apr 10, 2009 | Maytag Atlantis MAV6451 Top Load Washer
    I SAY REPLACE TIMER (POWER CONTROL BOARD)
    Jan 15, 2008 | Maytag MAH6500 Neptune Front Loading...
    Maytag MVWX700XL Top Load Washer MVWX700XL Logo
    121 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
