Question about Hotpoint HSS25GFP Side by Side Refrigerator
Not cooling, compressor is running but both lines are warm. fan is running also.
    Problem Solver:
  • 10 Answers
Check refrigerant pressure, if below 0psi (hg), need refrigerant, if not work before you charge up to 1.8 to 3 psi may be you has an escpape in the condensor internal lines, you can do this with 3 in 1 valve to refill and check the low pressure side
Posted on Jan 21, 2014
U-Line 75FF Bar refrigerator stopped cooling
it could be a problem start/run capacitor for the compressor or compressor failure
get a fridge technician in to test and get a quote
Most small fridges are cheaper to replace than repair
Jan 09, 2016 | U-Line Refrigerators
Compressor runs but wont cool
Make sure the compressor is running it should be vibrating and get warm after a few minutes. If it is indeed running the smaller tube to the compressor should be getting warm if not it could very well be the compressor has stopped pumping. If the fans are not running they could be controlled from the control board and will come on when the sensors on the evaporator get to a certain temperature. I does sound like the compressor is the problem.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
May 01, 2013 | Refrigerators
Frigidaire refrigerator/freezer side by side not kicking on. Both freezer and refrigerator not cooling.
If the unit is not cooling in either section of the appliance, you are experiencing some form of sealed system issue. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact your manufacturer and then a professional to move forward accurately.
Sep 03, 2012 | Frigidaire Refrigerators
Hi, The air con in my 2003 Audi A6 1.9 tdi 130 is blowing warm air the air con rad is fully gassed and all fuses are ok . Thanks in advance for any advice on how to fix
The only other thing then would be if the compressor is turning, engaging, and the cooling fan working properly. You should either be able to see the compressor clutch engage, as the switch is energized, or at least hear it click loudly when the switch is energized. If it is not, then there are sensors for the low pressure/high pressure line to tell the compressor when to function, that also have to be checked.
As the engine runs with the compressor turning, one line should be hot/warm, the othe,r (larger diameter hose) should be cool/cold, if the system is working properly.
If the compressor is turning when you have the A/C turned on, then see if the cooling fan is running as well. It must run to remove the heat and cause the process to function properly.
Mar 27, 2012 | 2003 Audi A6
My refrigerator freezer does not cool below 70 degrees. I just relace the start relay and now the compressor runs but the condensor fan won't work unless i give it a little spin.
Lubricate the condensor fan with a parifin based oil like Union 76 turbine oil or "Zoom Spout" oiler. These fans are notorious for the bearings drying up on them.
Being careful.... touch the compressor copper lines. One should be very warm almost Hot to the touch.
Also with the unit unplugged..... note that there is a coolant drier with a small capillary tube coming out of one end. Tap the side of this by holding a hammer handle (wood) against it and hit it on the side with a screw driver handle.
Check to make sure the evaporator fan in the freezer compartment is also running when the compressor is on. Anytime the compressor is running BOTH fans must be running. If you can not get the condensor fan up to full speed you will note that the chassis around the door seal area will be quite warm almost hot to the touch and the unit will not be cooling properly. Just for troubleshooting.... direct a fan at the condensor coils and see if the freezer compartment gets cold and that the chassis around the door seals is just warm.
Note about compressors in general.... if you unplug a unit.. it must settle / stabilize for 15 - 20 minutes so that the compressor can restart. Any power off periods less than 15 mins will result in the compressor cycling via the thermal overload every 4 minutes or so... and it does not run for more than 40 seconds when the overload kicks off the PTC relay power.
If you never feel the copper line off of the side of the compressor get hot then the unit has lost coolant.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Unit not cooling down,compressor running,condenser fan running. suction line just cool,condenser line barely warm.
Check if evaporator fan is running. Is there any frost buildup on freezers evaporator cover? If so you have a defrost problem (bad heater, defrost thermostat, thermister, defrost timer or circuit board ). If no frost and the freezer is warm then you most likely have a sealed system problem(leak, restriction, bad compressor) which is costly to repair.
Oct 19, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Cools at start up....then gets warm..compressor is warm.
I would need to know the model of this. However if the condenser fan is Not runing then the problem is that. If it is then it could be the sealed system and you will need a tech to check it out.
Apr 10, 2009 | U-Line 15R Compact Refrigerator
Refrigerator is running but not cooling
You will need to check that compressor is running. Many time its just the start relay that is easy to replace. If the compressor is warm and/or making a clicking noise its definitly the problem u can order the part on line 20.00
Mar 29, 2009 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
75 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
