Question about Dell Computers & Internet
Inspiron 1121 the battery states fully charged but if i unplug the mains power the computer dies,i have purchased a new battery and when it was installed it charged up ok then unplug mains and computer dies
Bogdan
  • 198 Answers
SOURCE: hp ipaq hx4700
Hello uwood, The problem you have is related to the battery's nominal tension value. For the pda to light up the amber led dispaying that the battery is charging the tension value at the battery pins must be above 3.27Volts. If this is under that value the PDA's charging circuitry woun't power up and therefore the amber led woun't turn on. The battery you have bought is probably defective or not compatible with your pda model. If you are shure this is not the case or if the battery works with other pda's (if you have the possibility to check that), try a master reset at first and if this doesn't help try a firmware (ROM) update, you may find the ROM files on HP's site. For more informations please reply back.
Posted on Apr 02, 2007
PABLOCSA
  • 1124 Answers
SOURCE: COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Posted on Oct 03, 2008
  • 16 Answers
SOURCE: Dell Inspiron Battery problem
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Posted on Oct 29, 2008
  • 114 Answers
SOURCE: Replacement adapter will not charge battery
Did the old one do the same thing? If true, your battery sounds like it is dead.
Posted on Jan 17, 2009
brector3
  • 1623 Answers
SOURCE: philishave8890 when the razor states fully
It sounds like the battery pack needs replaced. You will find the correct battery type at shaveroutlet.com. See link below. You will need to order 2 batteries
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To replace, you will need to remove the back cocer by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Sep 26, 2010
Jazzy power chair's battery runs out quickly afert being fully charged
I had the same problem I had to replace the batteries problem solved.But the batteries are not cheap
Apr 01, 2013 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Dell inspiron 1318 only a year old and battery says its dying, is this an error or do I really have to replace the battery, i do keep it plugged in all the time.
ofcourse the battery will mostly die ina year for most of the dell notebooks.... mainly when u always keep the notebook in the ac power and not using the battery power so much for your notebook...
the best way to keep the battery life extended is to use the battery until it is drained and then charge it and again use it fully until drianed ...
Jul 16, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
Inspiron9100 charges the battery, but does not run off it
you've got a dead cell in the battery pack. Replace the cell (there're howto's dotted around the web) or replace the battery pack.
Jul 21, 2009 | Dell Inspiron 9100 Notebook
The battery light remains on unless the power
If the computer will run on battery alone, and you cannot fully charge the battery, it's probably time for a new battery. The life expectancy is 2-3 years if treated right. Some people get a lot more life than others.
Here's a suggestion: when you run your computer, let the battery run fully down at least once a month. Do not leave it plugged in to line power all the time. Do not keep charging it when it is only a little bit discharged.
Jul 01, 2009 | Dell Inspiron 6400 Notebook
My dell inspiron battery is not charging.
PLz tell me about the model no.is it inspiron 1521 or 1501,From the problem u hav stated it seems that the battery is not getting charged.The computer is only running when the adapter is plugged in.
2 reasons:-
1.the batter have died
2.if it is a new computer or u have purchased a new battery,,then the problem is with the terminals from where the battery gets charged
Moreover some laptop batteries shipped by dell were faulty and dell launched the battery recall program,,specially of older inspiron models.give the service tag of ur computer to the dell technical support guy,,he will check it thru.plz keep me infmd about the prob,,and plz do reply if it gets resolved
May 12, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
Battery not running
Possible that whoever replaced your battery sent you the defective one back. Note the serial and model numbers on the battery, then request another one. When you receive the replacement, do a full recharge. Most new batteries come already half charged. Even in this state, take time to fully charge it (between 4 and 8 hours depending on the type and model). Then try running it on battery power. If the charge holds more than 2 hours on a new battery, youre good; less than an hour new, its defective. If after all of this still not resolved, request the company honor their warranty (usually a limited one year with purchase).
Mar 01, 2009 | Dell Inspiron Desktop with Intel Core 2...
Computers & Internet Logo
24 people viewed this question
Alun Cox
