Question about Pioneer DVR-X152 DVD±RW Dual Layer Burner
Can't get the enclosure open... HELP!!!
I bought a new dvd/br/mdisc drive because the drive inside my Pioneer case died. I found a couple lines on a Web site and they said to take the face plate off, the screws, then remove the bottom cover. That thing seems like it's glued on and I don't want to break a nail! LOL! I got the face plate off and disc tray out, unscrewed the 2 screws on the back as well as the two that are under the pads on the bottom, then nothing. I'm pulling at it but I can't even tell which side is supposed to come off. Someone please help!!!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
I'm not sure what exactly what are you doing, but try google it for: "dvd rom youtube"
Posted on Oct 19, 2013
  • Ray Savellano
    Ray Savellano Aug 23, 2014
    Once all the screws are removed you should be able to slide it out the front. If its an IDE drive it may still be seated into the connector block. Sometimes a little wiggling while firmly pulling will get it to release.
sandrew
  • 2961 Answers
SOURCE: Dvr-106d -Windows freezes,cant read new Dvds
if you have had two drives with the same problem i would check the ide cable and swap to another one if you have a master and slave twin connector ide cable, or even try the dvd rom on the same ide cable as the hard drive as you know that that ide connector and cable is working, unless you have a SATA hard drive in which case you won't be able to; but will still have a spare ide channel connector to try the drive on.
Posted on Jun 26, 2007
  • 46 Answers
SOURCE: Pioneer DVR-112D disc recognition
what i would do is install one drive as the master on ide 2, and the other as the slave on ide 1 and what OS are you using?
Posted on Sep 19, 2007
joebert
  • 29 Answers
SOURCE: pioneer dvd-rw dvr 112d
look for the mark at the top, MA for master, SL - slave, CS - cable select, these three are main connection for IDE designation using the plastic jumper, just follow where it is in your pioneer.
Posted on Jan 19, 2008
SOURCE: PIONEER DVD-RW DVR-K16A for TOSHIBA SATELLITE A100-233
I know this is an old thread, but I came across it looking for this solution. I found it elsewhere, but I thought that I might save the next person that looks for this some time. I found the solution here
http://forums.driverguide.com/showthread.php?t=21669
third post, thank you Jerry K for this.
It is a Windows thing, losing drives when installing/un-installing burning software...
If the drives are still listed in the Device Manager, delete them then, carefully follow this fix:
"Upper/Lower Filters:
a. Click on Start --> Run --> and type in 'regedt32' followed by the enter key
b. Expand the "HKEY_LOCAL_MACHINE" key (looks like a folder) by double clicking it (or clicking the "+" next to it.)
c. Expand the "SYSTEM" Key
d. Expand the "CurrentControlSet" Key
e. Expand the "Control" Key
f. Expand the "Class" Key
g. Look for a key containing the following string of letter and numbers:
{4D36E965-E325-11CE-BFC1-08002BE10318}
h. Highlight this key by left clicking once on it
i. On the right hand side you are looking for "UpperFilters" and "LowerFilters" under the "Name" column, once you find these delete them by right clicking on them and choosing "delete"
j. Exit the registry by clicking on the "X" in the top right hand corner of the screen.
reboot and now your drives should work fine.
Posted on Dec 03, 2010
Matrix12
  • 370 Answers
SOURCE: i have the pioneer dvd-rw
HI,
This is gonna be a bit complicated since were going to access your registry, but just follow all the steps and it will be much easier
>Click on START
>Type REGEDIT on the search bar on START Menu
>Expand HKEY_LOCAL_MACHINE
>Expand SYSTEM
>Expand CurrentControlSet
>Expand Control
>Expand Class
>Click {4D36E965-E325-11CE-BFC1-08002BE10318}
>Look for the Upper Filters / right click on it / click on Delete
>Look for the Lower Filters / right click on it / click on Delete
>Restart PC
>Try you CD / DVD ROM
If nothing happens, click on this link then click on RUN and follow the steps, then restart computer and try to run a disc again, if still nothing happens, theres a possibility that the problem is with the hardware side or the media player that you are you using...
Hope this will help...Your response is very much appreciated...
Posted on Feb 06, 2011
My older HP P07456 DVD drive came with a USB cable that cannot connect to my newer HP Elitebook PC. It has a separate power pin. Can I buy a different adapter cable to use it?
came with, you bought this DRIVE new? or found it
I added Came and USB to your post
now we know its not the lost power cable and is in fact the lost USB cable out of the original box from hp.
what is your story there,?
and external HDD, it is right? no , DVD special DRIVE,
it has 2 cables (data and power)
it came new with a power pack and 2 cables
new in the box.
1 with your funny uSB +1 pin for tc4200 pen tablets
2 usb for normal PC you lost.
1 power pack. 5v 3amps
RTM yet, the manual, lost that too?
Oops a hard manual to find this old.
read huffers post here. at omg real HP.com is this clear?
https://h30434.www3.hp.com/t5/Notebook-Hardware-and-Upgrade-Questions/HP-Ext-dvd-drive-EXT-MB-CRADLE-P07456-CNU402170K-4K0412-Rev/td-p/270630
that extra pin below is for only old tc4200 pen tablets
not for your PC, so if the normal, A-B cable is missing
the buy that.
the bottom is clearly marked, 5vdc 3.0amps, 15 watts or more.
it uses some very strange custom foxconn usb cable.
if it has power adaptor working and plugged in.
the std AB USB cable works.
at walfart cheap
https://www.walmart.com/ip/Tripplite-U022-010-Usb-2-0-Certified-A-b-Device-Cable-u022010/41099935
Jan 31, 2018 | HP Computers & Internet
I have a WD 500GB external drive wich I bought a couple of years ago and I believ I have fried the firewire interface, I have just purchased a dynamode 3.5" sata/ide enclosure but the connections do...
if you open up the WD external drive to get at the actual hard drive inside, you'll see the drive is either ide or sata then you can put it into the enclosure.
May 28, 2011 | Computers & Internet
USB port broke off. Can I connect to something else to get the data off the drive? I cracked open the case and it's a barracuda 7200 but I don't recognize the pin connections. Please help? Thank...
Yes just fixed mine. Went to radio shack bought a gigaware sata 3.5 external enclosure.
Took the harddrive out of old enclosure. pryed off external alluminum case to expose a panel that sticks out to the side where the broken usb plug went. Wiggled that off then placed in new enclosure fits good. secured with old screws. plugged it in and it works great. The new usb plug is much sturdier. The external case cost me about $40.00 and some change but Im glad i retreaved my data. I will never buy another seagate. Hope this helps...Alan
Jan 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Why i cant format my seagate 500gb potable hard drive, when format it in quick format its show an error that the hard drive not successfully formatted. what should i do? please help me, i need it asap....
The disk-drive inside the enclosure is "dying".
If the warranty still is valid, exercise the warranty to get it replaced, at minimal cost to you.
If the warranty has expired, open the enclosure, remove the disk-drive, and take the disk-drive to a computer-store. Buy a new, compatible, drive, and then "transplant" it into the enclosure, to "revive" your external file-storage appliance.
Nov 17, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
I have a Maxtor 1Tb External Hard Drive that I have only used a couple of times on my PC - I did a full back up a few months ago and all was well. I added a couple of things to it a couple of months ago...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 09, 2010 | Computers & Internet
I can't get my Simple tech mini 250GB to work Please Help!
Basically external usb drives are all the same. They have a usb interface and a drive interface. What happens is the usb interface usually dies after a while. The hard drive and your data are perfectly fine but you can't get at it.
There a re a few ways to fix this. One you can send to a data recovery center and spend $500 plus to get your data. You can sometimes send it in to the manufactuer but they don;t garrentee anything. Or you can buy a new external USB drive enclosure and put the drive out of yours into the new enclosure.
The drive inside is a standard laptop or small format harddrive. Absolutely nothing special about them. The hardest part of this is actually figuring out how to get the original enclosure apart. Once you get it open (or the tech does) then you just unplug the power and dat and remove any mount screws (maybe 4) and then revrese all of that into the new enclosure. Plug it in and you will have your data back. Thats all there is to it.
There are a couple of things to watch for. One is you may need a drive adapter dpending on what size or format of hard drive is in there. These are just a $3 cable adapter. The other thing is the odd enclosure formats or acesses the drive a differant way. If this is the case then waht you will need to do is get the same type of enclosure and move the drive. This is a bit more annoying and expensive but still cheaper than the data retrieval service by far. Even worse case you should be under $200, if its a normal usb setup then can be $20 plus labour.
Anyway don't panic your data should be fine.
Jul 08, 2010 | SimpleTech Signature Mini 250GB External...
My LG GH-22LP20 Super Multi DVD Rewriter cannot read anymore DVDs. It can only read CDs. How do I solve this? Help!
It's "dying" -- replace it. If it is an "external" casing, with an "internal" DVD-writer inside, you could open the casing, remove the "dead" drive, buy a new drive, and install it into the case.
Dec 26, 2009 | EXP Computer EXP CD-RW Station CRW 2400U...
Sabrent ECS-U35K Hard Drive Enclosure AC Adapter repair
I would sure enjoy helping you figure your problem. I've taken Electronic courses in the Navy and in college, so this shouldn't be too hard.
As far as the capacitor goes, manufacturers make several different products from the same PCB layout, just some don't have all the components. Once I see where the capacitor should be I can tell you if its necessary or not.
For the fuse, it sounds like there is a short somewhere further in the circuitry. Rather surprised it blew right off the bat, but people and machine alike can make mistakes when building things. I fixed a laptop power supply where they didn't even solder the source resistor for the switcher.
Upload your pictures, and we shall we what we can do with it!
Nov 06, 2009 | Sabrent ECS-U35K USB 2.0 External Drive...
Hard drive failure
If the board is the problem, perhaps. But often a drive failure is a head crash, in which case only data recovery services can help. Before you take apart the drive itself, make sure it is not a simpler problem-- one inside the enclosure.
There are a couple different possibilities here. 1) The hard drive has died. 2) The power supply for the external enclosure has died. 3) The controller circuitry for the enclosure has died. To determine what is the problem, you'll probably need to open the enclosure. Chances are, if the power light comes on, the power supply is working in some capacity.
Disconnect the drive's USB cable from the computer, and turn off the drive, usually with a small switch on the rear.
Now, place the drive flat against your head so that you can listen to the inside. Do not make any sudden moves at this point, shake the drive, drop it, etc. As the drive turns on, it is susceptible to damage.
Turn on the drive and listen for a "whirring" sound that indicates the drive is spinning up. After the initial spin up, it will become quieter. Make note of what you hear, and turn the drive off-- put it down after a few moments, giving the drive time to spin down again. A drive that is powered up can be damaged by handling it roughly.
If you did not hear the drive spin up, proceed with opening the enclosure.
If you heard it whine as it spun up, the problem is more likely with the cable you use to connect it, or the drivers/hardware in the system. Replace the USB cable. Uninstall your USB interface/hub inside the Devices control panel and Scan for Hardware Changes-- this may reload corrupted USB drivers.
Opening the Enclosure - First unplug the drive.
Open the case. Generally this is by removing two or more small phillips head screws on the back or bottom, sometimes they are covered by rubber feet
The outer shell will often pull off of or slide away from an inside chassis.
Carefully open the enclosure, taking care not to disturb cables. You should immediately see a fuse on the power supply you can check for replacement.
At this point you should also check to make sure the ribbon cable and power leads are firmly in place.
On the PCB (printed circuit board) look for burned or scorched areas, bulging or split capacitors (small, colored "can" looking components soldered on)-- also, is there a burnt smell?
If the fuse was blown, see if replacing it solves the problem. If the power connector and/or ribbon cable were not inserted fully, or were loose, unplugging them and then re-inserting them firmly may solve the problem.
If there are bulging capacitors, a smell, or discoloration, the power supply may be bad. Replacement enclosures can be purchased online for under $30. Be sure to get the right size (5.25" or 2.5" drive?) and interface (IDE or SATA).
If none have these have helped, the drive indeed may be bad. Many drives like these are under warranty. Look for the manufacturer's name and website on the drive. Most makers will have warranty information displayed prominently on their support page. They will often allow you to enter the drives' serial number to determine if it is under warranty, in which case they will issue an RMA (Return Merchandise Authorization) for repair or replacement.
If the drive is not under warranty, you can still purchase a "bare" OEM drive of similar capacity for around $110, and replace it yourself. Take care to purchase the right type of drive -- most are IDE but some are SATA. A wide ribbon cable means IDE. Simply make note of how it is installed in the enclosure (usually a couple screws) and mount the new one the same way. Close up the case and re-connect it to your PC.
Nov 09, 2007 | Computers & Internet
Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
Pioneer DVR-X152 DVD±RW Dual Layer Burner Logo
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
