Question about InnerIntimates Vaginal Renewal Complex Wash and Sponge, 4 oz
Write down the equation for the formation of the complex trans-K[Cr(C2O4)2(H2O)2.3H2O from the reactants K2Cr2O7 and H2C2O4.2H2O.
  • Grohen Techn... Master
  • 655 Answers
Limiting reactant:
The limiting reagent, or also called the "limiting reactant", is the chemical that determines how far the reaction will go before the chemical in question gets used up, causing the reaction to stop. The chemical of which there are fewer moles than the proportion requires is the limiting reagent.
Limiting reagent formula
There is a much simpler formula which can be used. However, you must first calculate the moles of both of the reagents in the reaction. Once the number of moles have been figured out, just simply fill in this equation (reagent 1 being the first reactant and 2 being the second):
When the answer to the formula is less than zero, reagent 1 is the excess reagent. When the answer is larger than zero, reagent 1 is the limiting reagent. The number shows how much in excess one reagent is from another. If the answer for the formula is zero, both reagents are perfectly balanced. The unit of an answer is in moles.
Posted on Oct 18, 2013
Hi I have Casio fx -991es plus calculator its give me wrong answer in complex number equations
It does not solve complex number equations. You can do simple calculations on complex numbers: addition, multiplication, etc. But nothing fancy.
Oct 26, 2015 | Casio Office Equipment & Supplies
Balance the equation _K2Cr2O7+_H2O+_S->_SO2+_KOH+_Cr2O3
2 K2Cr2O7 + 2 H2O + 3 S = 3 SO2 + 4 KOH + 2 Cr2O3
Mar 06, 2015 | Washing Machines
The equation for photosynthesis is?
In oxygenic photosynthesis water is the electron donor and, since its hydrolysis releases oxygen, the equation for this process is: 2n CO2 + 4n H2O + photons ? 2(CH2O)n + 2n O2 + 2n H2O. carbon dioxide + water + light energy ? carbohydrate + oxygen + water.
Dec 16, 2014 | Office Equipment & Supplies
Complex matrix
Is it complex or matrix? You can have only one mode at a time.What kind of equations? The solve function uses real-valued equations.
Complex numbers: You can add, subtract, multiply and divide. You can convert a number from rectangular to polar forms and vice-versa; you can calculate the absolute value of a complex number, or a conjugate.
All the operations are done in the Mode CMPLX.
Feb 04, 2014 | Casio FX991MS Scientific Calculator
I want to solve an complex equation on casio fx-570 ES Plus
Your scientific calculator is unable to solve complex equation with complex coefficients. You should try to solve by hand directly using the quadratic formula or by factoring the polynomial in z
failing that, another way would be to set z=x+iy, substitute this for z, carry out the algebra and try to separate real and imaginary parts. But your two equations will constitute a system of two quadratic equations. I am not aware of any general method to solve coupled nonlinear equations.
Good luck.
Dec 20, 2012 | Casio FX-115ES Scientific Calculator
Edit Casio FX - 9860G SD have complex equations??
Thhe Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Addendum.
The calculator CANNOT solve equations with complex coefficient. YOU can however convert the system of linear equations with ccomplex coefficients ( of the type you show) as a system of 4 linear equations in 4 unknowns; Split x into a real and an imaginary part, split y into a real and an imaginary part. Substitute Real(x)+iIm(x) for variable x in the equations; substitute Real(y)+iIm(y) for y in the two equations; do the algebra. In each of the original equations split the Real and imaginary parts. You should be able to derive 4 linear equations in unknowns Real(x), Im(x), Real(y), and Im(y).
Use the linear equation solver to obtain the solutions. Recompose x=Real(x)+iIm(x), and y=Real(y)+iIm(y)
Alternatively, after you create the system of 4 linear equations you can use the matrix utility to find Real(x), Im(x), Real(y) and Im(y) and recompose the x and y.
Mar 17, 2012 | Casio FX-9860G Graphic Calculator
Casio FX - 9860G SD have complex equations?? edit
The Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Addendum.
Mar 17, 2012 | Casio Office Equipment & Supplies
Your question (?) is not clear so I will not try to guess what you really mean.
Be it as it may, the Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Mar 16, 2012 | Casio Office Equipment & Supplies
In complex number mode, how to get out?
"Is there anything that I can do about this to stop my answers being complex numbers when solving cubic equations?"
You are making an assumption that is unwarranted.Namely that a cubic equation must necessarily have 3 real roots. This is not the case.
Let your equation be
If coefficients are complex you should expect some complex roots. Right?
If the coefficients are REAL then depending on the discriminant
you can have three cases
DELTA positive : three distinct real roots
DELTA=0 , the equation has a multiple root and all roots are REAL
DELTA negative: the equation has ONE real root and 2 complex roots that are complex conjugate of each other.
It suffices to look at the Tartaglia/Cardano expressions of the roots to know that more often than not there is going to be complex roots.
May 05, 2010 | Casio CFX-9850G Plus Calculator
Solve comlex equation
I do not understand what you mean by solve complex equations, but if you want to manipulate complex numbers here are the tools you need to enter your complex numbers. Operations and function evaluations do not need special symbols.
b4c488c.jpg Hope it helps.
Oct 31, 2008 | Casio FX-9860G Graphic Calculator
InnerIntimates Vaginal Renewal Complex Wash and Sponge, 4 oz Logo
171 people viewed this question
Top Grohen Technologies, LTD Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Grohen Technologies, LTD Vehicle Part and Accessory Expert? Answer questions, earn points and help others
