Question about Jenn-Air JDS8850 Dual Fuel (Electric and Gas) Kitchen Range
Dual Fuel model JDS8850 - the display faded - we can barely read it - I tried to open the front panel in order check the electronic control module but could not figure out how
  • stan kacmarik
    stan kacmarik Oct 18, 2013
    I checked it - the Energy Saver mode is not the problem. I suspect to be the LCD backlight (malfunction LED perhaps) - but cannot find the way to open the front panel.
  • 39 Answers
Http://jennair.com/digitalassets/JDS8850CDS/Use_and_Care_EN.pdf
That's the users manual. It may be in an Energy Saver mode.
Posted on Oct 17, 2013
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Electronic Display
This is a common problem with Jenn-Air and Maytag that I have found. There is no way to brighten the display and usually requires the replacement of the Electronic Oven Control (EOC) board. I think this may have something to do with the placement of the board and possibly being damaged by heat from the oven over a period of time. Do you do a lot of baking? Do you use the self-clean mode for your oven a lot? These seem to be contributors to these boards failing like they do. I know of one person who has replaced the EOC 6 times on the same stove. I don't know if this is the advice you were looking for, but I hope it helps you.
Posted on Jul 14, 2007
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Posted on Feb 28, 2009
Where is the body control module located in 2005 Lincoln las.
There is no BODY CONTROL module,but there is a Front Electronic module FEM, and a rear electronic module,REM (not the rock group,LOL!).
The FEM is located behind the driver's kick panel and the FEM is located on the right side down in the trunk.
The REM controls: Rear windows, , all rear lights, trunk opening, fuel door release, rear window defrost grid, trunk ajar switch, front passenger door lock, , front passenger door lock switch,rear door locks, trunk light, fuel pump, fuel level senders, antenna booster.
Hope this helps? don-ohio (:^)
Mar 17, 2017 | 2005 Lincoln LS
Why would the information panel in my car display, "Low fuel," "shocks inoperable," "service traction control," "do not exceed 80mpn," "service active handling," ect: and fuel gage reads empty?
G104
Instrument panel harness, below the battery tray, on the RH frame rail, ground for SP208 (CKT 851)
Splice Pack, SP208
Instrument panel harness, RH side of instrument panel, grounded to G104 (CKT 851)
G108
Forward lamp harness, below the battery tray on the frame rail
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gage defaults to empty if:
The PCM detects a malfunction in the fuel level sensor circuit.
The IPC displays a low fuel message on the DIC.
The check gages indicator turns on.
SERVICE ACTIVE HNDLG
Refer to ABS Description and Operation in Antilock Brake System
SERVICE TRACTION SYSTEM
SHOCKS INOPERATIVE
Refer to Electronic Suspension Control Description and Operation in Electronic Suspension Control
Mite be a good idea to have the vehicle check for DTC'S diagnostic trouble codes if the grounds are good !
This vehicle is equipped with a computer system capable of performing multiple engine and body control functions. Vehicle components such as windows, locks, mirrors, etc. are controlled directly by their system control module. Each system control module communicates with other system control modules on a serial data circuit. The vehicle system control modules are all attached to the serial data circuit that provides the data link communications. This data link, or serial data circuit, provides 2-way communication between various engine and body control system control modules.
I don't
Sep 09, 2015 | 2003 Chevrolet Corvette
Find a Diagram for 1989 Lincoln Towncar 4 Door Fusebox
this is for the base model
FUSE PANEL IDENTIFICATION (1983-90 LINCOLN TOWN CAR) The fuse panel is located in the instrument panel to the left of the steering column. To expose fuse panel, remove lower steering column finish panel.
Fuse & Circuit Breaker Identification
· 1 - 15 Amp Stoplights, Hazard Warning Lights, Speed Control Module, Trailer Tow Relays, Cornering Light Relay (1983-89)
· 2 - 8.25 Amp (Circuit Breaker) Windshield Wiper/Washer
· 3 - Blank
· 4 - 15 Amp Taillights, Side Marker, License Light, Parking & Coach Lights, Cluster Illumination, Trailer Tow Relay
· 5 - 15 Amp Turn Signal & Back-Up Lights, Trailer Tow Relay, Cornering Light Relays, Heated Rear Window Relay, Rear Defrost (1988-90), A/C Clutch & ATC Module (1990), Load Leveling (1990)
· 6 - 20 Amp Heated Rear Window Control, Speed Control Module & Clock Display, Illuminated Entry Module, Power Window & Police Accy Relays, Fuel Filler Door Release (1983-87), A/C Clutch & Cornering Lights (1983-89), Deck Lid Release (1987-90), Tripminder
· 7 - 10 Amp Daytime Running Light Resistor (1990)
· 8 - 15 Amp Dome LP-Clock, Key Warning Chimes & Electric Mirrors, Courtesy & Visor Mirror Lights, Autolight & Illuminated Entry Modules, Tripminder, Electronic Radio Memory, Trunk & Underhood Lights
· 9 - 15/30 Amp Heater Blower (15 Amp), AC/ATC Blower (30 Amp)
· 10 - Blank
· 11 - 20 Amp Radio & Power Antenna, CB Radio
· 12 - 20 Amp Door Cigarette Lighters, Power Seats & Door Locks (30 Amp), Tailgate Power Window (1983-89)
· 13 - 5 Amp Illuminated Outside Thermometer, Instrument Panel Lights
· 14 - 20/25 Amp (Circuit Breaker) Flash-To-Pass, Sun Roof, Power Windows
· 15 - 10 Amp Taillights, Parking, Side Marker/Coach, License Lights
· 16 - 20 Amp Horn & Front Cigarette Lighter
· 17 - 15 Amp Electronic Cluster, Message Center
· 18 - 10 Amp Warning Indicator Lights, Throttle Solenoid Positioner, Low Fuel Module & Autolight System, Dual Timer Buzzer & Electronic Chimes, Electronic Message Center
Feb 11, 2015 | 1989 Lincoln Town Car
Electrolux Perfect steam washer has a faded lcd screen. Very hard to read at this point, can someone tell me how to order and replace it Please?
Thank you for your post, Glen Wagner!
In order to get proper replacement parts for your Electrolux washer you would need to have the model number available. I would recommend reaching out to the manufacturer, to guarantee the parts are correct. If you need assistance with installing the parts you may want to consult a professional for proper installation of replacement components. I hope this information has been beneficial. -Matt
Oct 13, 2014 | Electrolux 4.2 Cu. Ft. Front Load Washer...
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
Our jenn air model js9860aab control panel buttons on the panel do not respond--is there a rebuild kit available to repair this -- because without these buttons, the convection oven of this duel fuel range...
no.. u must replace the touch pad assrmbly that whole unit.... i think u have a jds9860aab i believe... the part number u would need would be 74005750 it is for sale through sears at $272.00... u might need service.. u can take a look at part at repairclinic.com just type that part number in. ohhh also i believe this is a backordered part so most companies would prob take 2-3 weeks to get soo hope this helps..
Jan 28, 2010 | Jenn-Air JDS8850 Dual Fuel (Electric and...
Electronic Display
Feb 23, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JDS8850 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
