Question about Technics SA-DX1050 Receiver
Need to replaced the cooling fan, whats the # of the fan?
I have a 2001 cavalier that is overheating. I replaced the thermostat and it still overheats. There is lots of heat from the heater. What can the problem be?
Your radiator may need flushed or replaced.
Your Fan my not be working properly.
Your Catalytic Converter may need replaced.
Dec 11, 2014 | 2001 Chevrolet Cavalier
My 99 Honda Accords keeps overheating on and off when my car is on park or at a long stop. What can be the problem?
FIRST OF ALL I WOULD REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP THEN CHECK SEE IF COOLING FAN RUNNING.WHILE CAR OVERHEATING. IF NOT CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD THE ENGINE COOLANT TEMPERATURE SENSOR COULD BE FAULTY.HOT WIRE SEE COOLANT FAN WORKS IF NOT, COOLING FAN MOTOR BAD NEED REPLACING.IF COOLING FAN MOTOR WORKING PROBLEM COULD BE IN FAN MOTOR WIRING OR PCM FAILED.
Sep 20, 2011 | 1999 Oldsmobile Alero
I just bought a 1995 jetta and it's running at 260 degrees. Is this too high, and if it is then what would be causing this?
CHECK TO SEE IF BOTH COOLING FANS RUNNING ARE RUNNING WHEN ENGINE RUNNING START OVERHEATING IF COOLING FANS NOT WORKING CHECK COOLING FANS LARGE FUSES IN THE ENGINE COMPARTMENT OR YOU COULD FAULTY COOLING FANS THERMO SWITCH BOTTOM LEFT SIDE OR RADIATOR.IF COOLING FANS IS WORKING WHILE ENGINE RUNNING.RADIATOR CORES AND HEATER CORE COULD BE CLOGGED.COOLANT SYSTEM NEED FLUSHING. THE THERMOSTAT PARTIALLY CLOSED CAUSE ENGINE OVER HEAT.CHECK WATERPUMP WEEP HOLE IF LEAKING WATER PUMP NEED REPLACING.
Jul 21, 2011 | Volkswagen Jetta Cars & Trucks
Cooling fans are not running when car gets hot. what could be the problem. I have changed the cooling sensor and relay switch recently Yesterday the car overheated, the oil was a quart low.
Hello and welcome to FixYa!
Have you tested the cooling fan itself? If not then I suggest that you pull out the fan, tap a wire one on the negative battery and other to the positive battery terminal. Tap it to the connector of the fan motor, if it doesn't run then you will need to replace the cooling fan itself. Faulty cooling fan motor can be the issue here and will surely need replacement.
Hope this helps and thank you for using FixYa! Have a good one!
May 25, 2011 | 1996 Plymouth Breeze
Cooling fan makes little noise now and then on my xj6.
mcdevito75, This could be some wear in the bearings of the cooling fan, keep an eye out for the noise getting worse, if so replace the fan with a new one. These cooling fans are sealed units so when the niose gets to be too much you"ll have to replace with brand new.
Jun 17, 2010 | 1995 Jaguar XJ6
What is the value of rectifier used for cooling fan in smps
its cheaper to buy a replacement fan because if you make a mistake during manufactuer then it may cause other problems,replacement fan in NZ about $30 and comes with warantee
Apr 27, 2010 | Dell (6F858) Cooling Fan
Noisy fan
You need to replace the fan. Measure the fan you have now and buy one the same diameter. Then remove the old fan and put in the new fan.
May 28, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Replacing cooling fan clutch????
Hi
Yes you need to replace what is called the Fan Viscous Coupling Unit.
Then swap over the fan blades.
Quite straightforward.
Good luck !
John.
Jan 19, 2009 | 2001 BMW 325
My cooling fan will not turn on 2000 ford contour
you need to replace the cooling fan because the resistor is in the cooling fan and it is best to go to a salvage yard and have them look it up on a computer and it will tell what fan will work on your car
Jan 12, 2009 | 2000 Ford Contour
Fan Noise on Dell Dimension 8100
All computer fans have a general design.  The name in front of "fan" really refers to the designation.  You'll see case fan, processor fan, CPU fan, cooling fan, etc.  In the case of CPU/Processor fan, some are sold with heatsinks (the metal block sitting on top of your CPU).
The first thing you want to do is make sure the fan is clean.  Chances are dust buildup is causing the excess noise.
If that's not the case and you're looking to replace the fan, then you first need to find out the size of the fan. General sizes(diameter X width in mm) are listed on this page:
http://www.svc.com/case-fans.html
Generally, you're looking for something that will match the size of what you're replacing & push enough air at a reasonable noise level to cool the heatsink/CPU.  You want to stay in the area of 30dBA max for noise.  You also want to see if it has a 3-pin or 4-pin connection.
For example, if you have an 80mm fan, I would suggest something like this:
http://www.svc.com/saf-b82-19.html
It's pretty quiet with good airflow.  Also, it has a 3-pin connection, but includes an adapter for a 4-pin connection.
Z
Oct 27, 2007 | Dell (6F858) Cooling Fan
Technics SA-DX1050 Receiver Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
