Question about Frigidaire Refrigerators
I have a fridgedaire side by side, purchased in 2008. The interior light delays 15-20 seconds rather than immediately. Anyone have any ideas.
    New Friend:
Check for ice at the door switch in the freezer or goop in the fridg door switch
Posted on Nov 15, 2013
My interior light won't come on in my 1999 Buick Lesabre. I have checked the bulb & the fuse. Can anyone help me with this problem? Any ideas are sincerely appreciated.
Courtesy Lights
The courtesy lights come on under the following conditions:
Any door is opened.
The interior lamp switch is in the ON position.
The keyless entry transmitter unlocks the doors (illuminated entry).
When the key is removed from the ignition switch with all of the doors closed, the courtesy lights light for approximately 25 seconds before fading out.
Battery positive voltage (B+) is applied at all times through the IP fuse block CTSY LP/PWR MIR fuse 6A via CKT 640 (ORN) through the body control module (MALL) to the courtesy lights via CKT 1732 (ORN). The MALL provides a ground through CKT 156 (WHT) for the courtesy lights under the following conditions:
The MALL receives an input from a door being opened.
The MALL receives an input from the interior lamp being turned ON.
The MALL receives an input from the doors being unlocked using the keyless entry transmitter.
The courtesy lamps then light.
When the courtesy lights are activated by opening and closing a door, the courtesy lights will remain on for approximately 25 seconds before fading out after all of the doors are closed. If the ignition switch is turned to START or RUN within the 25 seconds, the lights immediately begin to fade out. If a door is left open, the MALL removes battery positive voltage (B+) to the courtesy lights after 10 minutes. When the courtesy lights are activated by the interior lamp switch, the lights remain on as long as the interior lamp switch is in the ON position. When the courtesy lights are activated by unlocking the doors using the keyless entry transmitter, the lights remain on for approximately 40 seconds. If the doors are locked using the keyless entry transmitter within the 40 seconds, the lights immediately begin to fade out.
Body Control Module (MALL) Diagnostic Mode
For a detailed explanation of the MALL module diagnostic mode, refer to Body Control Module Cell 51.
What interior light ? Dome , courtesy lights etc....They don't work with switch, keyless entry , door opening ?
What
Dec 03, 2015 | Buick Cars & Trucks
Interior light delay not working
That is normal operation, as long as the door is open the door ajar switch senses that and keeps the interior light(s) on.
Sep 06, 2017 | 2010 Chrysler Town and Country
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
2009 ford focus dome light stays on
Are you sure that the thumb wheel switch beside the headlamp switch is not turned all the way up until it clicks?
If it is staying on for 10 minutes this means that the smart junction box is seeing a demand for the interior lights from something like a door ajar switch or the thumb wheel. If it sees that the igntion is in the off position it will turn the lights off after 10 minutes to conserve battery power.
Normal operation is:
The interior lighting delay feature provides temporary illumination of the courtesy lamps after the doors are opened and then closed. The interior lighting delay feature keeps the courtesy lamps on for a period of 25 seconds after all the doors are closed. If during the 25-second delay time the SJB detects that the ignition has been switched out of off, or if the vehicle is locked using the RKE, the courtesy lamp illumination is discontinued
Mar 24, 2009 | 2009 Ford Focus
Two switches with two hallway lights-one delays going on.
What it sounds like to me is that the second light may have fluorescent bulbs - either the compact fluorescent type or maybe a circular bulb. The fact that when you turn off the switch and then immediately on and it works fine, also makes sense if that is the case.
Jan 28, 2009 | Fantech DB10 Pressure Switch Kit w/ Delay
Can I change the off delay on my lights
You can do this through the onboard computer in the dashboard try going through the setup functions by using the setup button on the dash.
If i had one in front of me i could change it in a heartbeat its very easy to do
Nov 28, 2008 | 2008 GMC Sierra 2500HD 2WD
2008 GMC Sierra Ext. cab runnungboard lights
yes wire the runningboard lights together and then to the interior light post on fuse box or to interior light switch on drivers side door
Nov 08, 2008 | 2008 GMC Sierra 2500HD 2WD
Interior lights will not turn off. all doors checked for proper closure
check you dimmer switch. if your dimmer switch has been moved uo than your interior lights will come on and stay on until shut off.
Aug 02, 2008 | 1997 Ford Windstar
Refrigerators Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
