Question about Bowflex Tc5000 Climber Treadclimber Treadmill Bow Flex Tread Climber Tc-5000
Start shuts down machine and blows circuit breaker
    Top Expert:
  • Bowflex Master
  • 12,223 Answers
See the video attached. and proceed according. However you must test the power cord for short circuit. some wires is touching each to another. Or the outlet wall the wires are loosing touching each to other and blowing the c.breaker, or call some electrician for to fix it.
God bless you
Posted on Oct 18, 2013
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
1997 Harley Ultra Classic 30 amp main breaker pops while riding. Also blows 10 radio power fuse
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the switch, circuit breaker or the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 19, 2012 | Harley Davidson FLHTCUI Electra Glide...
Is there a fuse on the Whirlpool 24 in. DU910PFG Built-in dishwasher? ... it just stopped working!
Good evening, There is no fuse that would shut down everything.Check for switch under sink or your home circuit breaker.Then it could be your door switch which shuts every thing down .It may be stuck open.Sometimes a door slam will get it going but still needs replacement.$40 part though.Switch is located behind console and can be checked with ohm meter.Sears Parts Direct shows blow up of your machine.
If it was your circuit breaker and it blows again ,you have a short and you'll need tech. to troubleshoot or maybe there is another load on that circuit (like toaster etc)
hope this helped
Aug 16, 2011 | Whirlpool 24 in. DU910PFG Built-in...
Older Kenmore model 110.82673110 washing machine keeps tripping the GFI. Replaced GFI but problem persists. How can I fix this?
i would install a regular outlet... and if the circuit breaker blows. then their is a direct short within the washer .i never heard of GFI being used on a washer ..remove it.. their may be other outlets on this circuit also that can adding to it tripping. like frig.. find out what is on that circuit by shutting off the breaker for washer see what else goes off...
Aug 24, 2010 | Kenmore Washing Machines
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
BEKO WBF 6004 XC : causing the circuit breaker down
I think you will find the fuse in the plug has blow and secondly there is probably a short circuit in the heater element as before the wash cycle starts it needs to heat the water and that's when the power fails eric
Dec 25, 2017 | Washing Machines
My washing machine keeps shutting down and blowing a fuse.
You must have a short circuit ,try disconnecting things start with the heater element, disconnect one wire see if it still blows...next try motor plug, until the fault clears at least this tells you what the problem part is.....
Apr 11, 2010 | LG WM-2077C Front Load Washer
Just started blowing the breaker. Late in the day so I turned it off.
4 grp Rio, probably running on a 50Amp breaker. Check the electrical connections on the pump(if you model has an internal pump it would be above the switch there is a 3 connector bridge.
Check the switch, there may be loose connection, also check the plug and receptacle.
Check the element connections that would be the most likely suspect for a breaker blow.
Check to make sure that nothing else is on the same breaker as the machine.
May 25, 2009 | Saeco Rio Vania Group 4 Espresso Machine
My GE Microwave oven, blows the circuit after running for a short while
I sent you private e-mail.
Door switches or problems with wiring or the breaker, or something esle on the same breaker (a "no no") are the most likely problems.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 09, 2007 | GE JVM1630 Microwave Oven
Code "PF" = N/A
Soft Touch -PF- means power failure, nothing else. Most likely the problem is not with the dryer. The circuit breaker became too weak for the dryer load. I beleive replacing the circuit breaker will solve the problem. Gendos...post back
Feb 25, 2007 | Whirlpool GEW9250 Electric Dryer
Bowflex Tc5000 Climber Treadclimber Treadmill Bow Flex Tread Climber Tc-5000 Logo
119 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
