I have almost no water in my kitchen faucet. We have checked the aerator and that is clear. What should we do?
First of all we like to check the easy/cheap things first.
1. Are the shut-off valves closed lightly?
If they are closed, open them.....easiest fix of them all.
2. If the valves are open then possibly a washer is shifted.
Turn off the water supply at the valves under the sink. Remove the handles by removing the set screw under the handles. There should then be a packing nut which holds all of the "guts" of the faucet in. Remove this nut and pull out the long stem. On the bottom of this stem is a flat washer that may have been damaged or is just slightly shifted. EIther way, I would replace it if the faucet is more then a few years old as it is cheap and you already have access to it. WHen replacing the valve stem, be sure to use a plumbers grease on all rings and seals. The rest of the replacement is the same are the removal.
Hope this helps.
same problem what is asto
Turn off the water. Dissemble the stop or remove the lines from the stops. Look for obstuctions.
