Question about iHome iP46 Rechargeable Portable Stereo System for iPhone/iPod
How do I get the case off of an iP46 so I can fix the AUX jack?
    New Friend:
Pull the top of the Grey mesh of the speakers of (that metal cage around the audio sound ) and once that's off there are screws... I pulled really hard only to figure out that's all you need to do -.-
Posted on Nov 07, 2013
    New Friend:
Pull really hard
Posted on Oct 17, 2013
How do I open my iHome IP46 to replace battery?
Try Googling (iHome)(IP46)(manual) without parens.
Jun 19, 2017 | iHome Audio Players & Recorders
How come my aux jack isn't playing my music the aux jack is kinda loose what to do?
You may have to remove the unit and disassemble it to rectify a poor soldered joint on a printed board. Worst case scenario these days is that the input jack is mounted with special equipment and is surface mounted. Make and model would be good here, If its a more recent unit can you use blue tooth?
Feb 25, 2015 | Car Audio & Video
2010 Equinox radio stops playing and "Aux Input Device" is displayed.
Your first option is to replace the radio with an aftermarket. First and easiest. Second option, (You must be able to tear apart the radio and be able to solder). Just bad solder joints. Usually at where the face and radio meet. I have fixed many of them. Most don't want to pay for the fix. Takes time. Yeah, you loose some stuff, but aftermarket is cheaper, depending on the kind of stereo you put in.
Dec 15, 2014 | 2010 Chevrolet Equinox
The plug works because the socket switch is turned on and the volume control button is green but when I plug in the auxiliary cable there's no sound? Is there something wrong with the inside of the...
Was the second aux cable you tried new or old? If both aux cables were older, you might possibly want to try (not necessarily buy) plugging in a new one. If you have done that: How old is this receiver? Brand new or older, if older it could be build-up inside the jack causing a break in the connection between jack and aux cable. If this is the case then a simple cleaning with a Q-tip and some alcohol could help immensely. If that's not the case, it sounds like you could have a short in the jack.
Jul 13, 2011 | Audio Players & Recorders
Can you connect two Bose Wave radios together for more sound volume?
There are several types of Bose Wave Radios - the one pictured (the others likely do, too) have "Line Out" and "Aux In" jacks. Each consists of a Left and Right pair of RCA type jacks. Simply connect the "Line Out" jacks of one of the radios to the "Aux In" jacks of the other. Select the "Aux" source of the radio that has the cable connected to the Aux In jacks. Whatever is playing on the main radio (CD, Tuner, or other input) will be heard on the second radio - if the Aux source is selected.
Please rate this reply if it was found to be helpful - good luck!
Jul 03, 2010 | Bose Wave Radio
Have Mack 12 speed gearbox from R model with broken selector for on top,rear case needs to be unbolted in order to slide out selector shaft. Do we need special tools or with block and tackle can this...
If I am reading your post correctly. You wan't to split
the aux. transmission from the main, just enough to
change the shift rods. I don't rember the last mack I
did it's been a while. The last one was a quad box in
an autocar. That was done on the floor, by blocking
the main with pieces of 2x4's+4x4's and using a
home made flat cart under the aux. But I think you
want to do this in frame. In that case you will need
a transmission jack. If the mount is under the main
use the jack to slide the aux. back. If not suspend
the main with heavy jack stands. And if needed a
heavier piece of channel iron. Also do not do this
alone. Make sure you have plenty of help with you.
One time I did not. But lived to warn about it.
Hope this is of some help. Be careful.
Good luck.
Feb 02, 2010 | 1987 GMC R3500
I have an LG 37LC2D LCD TV that is locked.
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) are the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG 37LC7D 37 in. LCD HDTV
Aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Aug 13, 2008 | Kenwood KDC-MP435U CD Player
Aux. Input Jack
I had the same problem. I opened up the box and used a glue gun to reattach the aux jack from the inside.
Jun 18, 2008 | Bosch PB10-CD Radio/CD Boombox
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
iHome iP46 Rechargeable Portable Stereo System for iPhone/iPod Logo
357 people viewed this question
Top iHome Radio Communications Experts
eradiostore
eradiostore
Are you an iHome Radio Communication Expert? Answer questions, earn points and help others
