Question about McCulloch Power Mac 310/320/330/340 Chain Saw Manual Package Owners, Shop, Parts
Mccullough 310 need fuel pickup part - McCulloch Power Mac 310/320/330/340 Chain Saw Manual Package Owners, Shop, Parts
How do i start the mccullough mt 270 grass strummer
You have to start at the beginning. Do you have spark and fuel?
Sep 16, 2014 | Garden
Need manual 14" mccullough electric chainsaw eager beaver
McCullough 14" Electric Chainsaw User Manual
(NOTE: This is also useful for the EagerBeaver Electric Chainsaw)
Online Manual:
http://www.manualagent.com/mcculloch/ms1415/users-manual
McCulloch MS1415 User Manual
PDF Manual to download:
https://libr2.com/get/mtd-ms1415-2409
Oct 24, 2012 | Garden
Hi, my mccullough 32cc leaf blower stopped running??? loose parts in fuel tank???
The cylindrical part on the end of the hose is the fuel filter, the other part sounds like the the insert from the end of the return hose to the tank, if the filter has come away from the pipe dirt will now have entered the carc and will now need cleaning, the insert is to stop the return hose from coming out of the tank, you would have to remove the return hose to re fit this but it is not realy overley importent, if the fuel filter is still connected to the hose, pull it off and replace wiyh a new filter and try again.
Aug 27, 2012 | Garden
I have a Craftsman Leaf Blower (made by McCullough) and the fuel tank is leaking - need a new tank. Model #316-794990, Part #MC 9228-334506. Thank you!
Before you spring for a new tank, check that the leak is not coming from around the fuel lines. If the fuel lines are not soft and plyable then they can not seal with the tank and may be the cause of the leak. They are replaceable and if that is the case you can get fixed up for a few dollars in parts.
Sep 13, 2011 | Craftsman Blower Attachment
Fuel mix ratio for 110 12'' McCullough chainsaw
The OM for my MAC 110 says 40:1 (1 gallon of premium fuel to 3.2 ounces of quality oil).
I operate it on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality oil) without a problem.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 02, 2010 | McCulloch Garden
2003 ford focus fuel filter replacement
  1. Depressurize the fuel system. For additional information, refer to Section 310-00 .
  2. Disconnect the battery ground cable.
  3. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  4. Disconnect the evaporative emission pipe.
  5. Remove the fuel filter outlet pipe. For additional information, refer to Section 310-00 .
  6. Disconnect the fuel filter inlet pipe. For additional information, refer to Section 310-00 .
  7. Remove the fuel filter and bracket.
  8. Remove the fuel filter.
    1. Remove the bolt.
    1. Slide out the fuel filter.
you may need a special tool to release the qucik connects for the fuel lines from the filter.
Dec 31, 2008 | 2003 Ford Focus
McCulloch Power Mac 310/320/330/340 Chain Saw Manual Package Owners, Shop, Parts Logo
42 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
