Question about Garden
What cc is a poulan pn3613 chainsaw please - Garden
    Sergeant:
    Champion:
  • 320 Answers
If its the pro series it is: 42 cc
Posted on Oct 25, 2013
Testimonial: "Hey thanks for that George, that name poulan can be a bit scary when buying second hand."
  • George Oct 25, 2013
    You welcome. Thanks for responding back. George
dontbother10
  • 2220 Answers
SOURCE: 42 cc engine
I didn't see a complete engine assembly at Poulan. Ask them.
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1 (800) 554-6723 or
http://www.poulanpro.com/node4033.aspx
A new cylinder and piston are about $75.00, plus shipping, if available here:
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
An inquiry for repair at a local saw shop might be worth an inquiry.
An entire new saw PP4218 is $150.00 @ Walmart.
Did you borrow someone else's saw and run it on straight gas? HTH
Lou
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: HOW DO U AJUST CARB ON A POULAN CHAINSAW 36.CC
Start with "H & L" at 1,5 CCW from lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. I hope this is helpful
Lou
Posted on Jan 16, 2010
  • 4088 Answers
SOURCE: Bar oil leaks into storage case when chainsaw not
The easy fix is to drain the oil tank when not in use. Many saws will leak some oil initially, but should not continue to do so. If it is making a large puddle, oil is getting past the oil pump which may be worn from long use. Make sure the tank vent is not plugged as heat from the engine can increase pressure in the tank thus forcing oil out. Hope this helps!
Posted on Mar 28, 2010
  • 2239 Answers
SOURCE: My Poulan 18in 40 cc
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Posted on Apr 16, 2011
  • 2239 Answers
SOURCE: Chain will not stop spinning
I would say it has an air leak, through a gasket or crank seal, make sure the carb is tight and sealing properly.
Posted on Jun 15, 2011
Poulan chain saw 2050 2.0CL
The Poulan Chainsaw 2050 is a 36cc model with a 14" bar and chain.
Sep 02, 2014 | Poulan Garden
How does the throttle cable route on a poulan pro 260 42 cc chain saw
HOW DO I INSTALL AN ACCELERATOR CABLE ON MY 260 PRO POULAN CHAIN SAW?
Oct 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where is the chain tensioner screw?
A link to a Poulan 3516AVX - OM follows:
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137248.pdf
Poulan calls it a “Bar Knob”
See pages 7 & 8.
An abbreviated procedure is on page 2.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa
Aug 14, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Re attach pull cord on Poulan Super XXV Counter Vibe Chain Sam
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 25, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Lost my manual for my poulan pro 255 chainsaw the model number seems to be missing on the machine. i have a balance spring underneath thats broken near the rear of the chainsaw. need a part number for the...
If looking for parts your OM is of little value. You can find an IPL (exploded parts list) here (only one PP255 listed):
http://www.ordertree.com/modelinfo/PWE/PP255-Gas-Saw/75.PP255-Gas-Saw.1.59.1.html
Rear vibration (isolation spring)s appear to be item 5 or 59 on the "Exterior Assembly" print.
Poulan replacement OM.
http://72.3.225.179/manuals/87722e.pdf
There is contact us number in the OM if you want to contact Poulan. HTH
Lou
Feb 14, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Dec 05, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
