Asus monitor vw223 When I turn on my computer,
Asus monitor vw223 When I turn on my computer, monitor can't turn on. Signal light of monitor wont stup lighting and monitor cant be turned off.
hardrocko
  • 1476 Answers
SOURCE: When it's turned on, the light on my monitor doesnt show any signal of power supply
I'm assuming that you mean the green indicator light is not on. This could be caused by a host of problems. Assuming that you know the AC receptacle is live by testing with a standard light the next step would be to unplug the unit and remove the back. Check the fuse for continuity. If the fuse is good you have a problem with the power supply or a short which is keeping the power supply from powering up. The most likely culprit is the Horizontal Output Transistor. Unless you are an electronic tech and know how to check this you probably need to take the unit to a shop for further diagnostics and repair.
Posted on Jun 22, 2006
SOURCE: I turn my monitor on and it displays BENQ and then goes to -No Signal Detected- Power light changes to orange..help?
IT MUST BE A DPI.IF UPPER THAN 60Hz THE PROBLEM WILL BE OCCUR AGAIN.I THINK
Posted on Oct 04, 2007
SOURCE: Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Posted on Sep 27, 2008
SOURCE: No Image on Monitor Westinghouse L2046NV
well i just had this problem this morning i woke up turned on the monitor and it came on but went out. but i soon found out it was not the display that is not coming on its the black light. if you look closely you can see the display but there is no light to light it up so you can see. it doesent seem to be anything wrong with the circuit board just the black light i am going to be taking the monitor apart to see if there is anything me or any of you can do for the monitor to fix it.
Posted on Dec 15, 2009
budmrtn
  • 11361 Answers
SOURCE: samsung 906BW monitor wont turn on, power switch
This model is released in June 2007, more likely to have bad caps by now, just other failed SAMSUNG monitors here: http://s807.photobucket.com/home/budm/allalbums
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Post back what you find.
Posted on Apr 03, 2010
How can I troubleshoot an Asus monitor that won't display an image?
check you surface pro display setting.
check if it is enable to give signal to 2 display image of surface pro
Aug 31, 2014 | Computers & Internet
I have an Asus, model # VH197D 19"Led Monitor,
CHECK THE SIGNAL CABLE OR YOU CHANGE IT, ALSO THE ON BOARD CONNECTION
Sep 27, 2011 | Computers & Internet
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
Why does my asus monitor always read "no signal".
nah that happens with me sometimes..
have you connect the cable properly?
if that still can't make it works, first turn on your PC and monitor..
then plug off the cable that power them, so that your computer and monitor will suddenly off..
plug it on again, then your monitor will work again..
that works on mine cause my CPU is too old and had a power problem..
May 07, 2011 | ASUS LCD Monitor
Monitor says no signal
Fix the power cord firmly! hold it and fix it such that you wont get a shock! also fix the cord from monitor to CPU firmly! I prefer you to turn off you computer..clean the power cord by blowing the dust on sockets and pins and then fix it firmly and turn on computer again! Make sure power is not running in the cord while you clean it!
Oct 17, 2010 | ASUS VW193T Monitor
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
No signal sent to monitor
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Solution
Mar 13, 2010 | ASUS P4S533-MX Motherboard
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
A mind of its own
check the cmos battery and the power suply. lok for swollen compassitors
Dec 30, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
