Question about Singer CSP1 Iron
My singer magic press4 don't heat when turn it on
2 Suggested Answers
SOURCE: my singer magic press 4 iron comes on but the plate will not heat
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
Posted on Nov 05, 2009
How do I find out why my singer magic press 4 won't work? no light comes on, no heat
Assuming you have tried different power points in the house, it is likely the mains cable plug of the iron is faulty. Worst the cutoff fuse or control inside has tripped. Would suggest if mains cable or plug is ok then buy a new iron as these can be risky to repair without knowing what one is doing.
Aug 26, 2014 | Irons
Singer magic steam press 7
singer magic 7 is used carefully as it is closely to iron so check if wires are connected correctly
Jan 22, 2014 | Singer Electronic Steam Press Iron
I am looking for a manual for a Singer Magic Steamer 7.
TENGO UNA PLANCHA MSP7, LA CUAL PRENDE PERO NO CALIENTA, AQUI EN PARAGUAY NO HAY QUIEN ARREGLE, NECESITO SABER SI DISPONEN DE PLANOS ELECTRICOS Y DESPIES DE LA MISMA, DESDE YA MUCHAS GRACIAS.
MI MAIL ES:
sabatel2010@hotmail.com
Dec 30, 2010 | Singer Electronic Steam Press
Instruction manualfor csp-1 singer
Located here
http://www.amazon.com/Singer-CSP1-Magic-Steam-Press/dp/B00006IV4K
Jun 25, 2010 | Singer CSP1 Iron
Lost intruction manual Magic Steam Press csp-1
Follow the link or copy it to your browser - http://www.singerco.com/accessories/manuals.html - and search for your Singer.
Kind regards Ryno
Jun 20, 2009 | Singer CSP1 Iron
My singer magic press 4 iron comes on but the plate will not heat up. I turn it on one day and it just would not heat up.
Jun 18, 2009 | Singer CSP1 Iron
SINGER MAGIC PRESS 4
I have the singer magic press 4 but the control button is missing can it be replaced
Mar 25, 2009 | Singer Irons
Singer steam press csp-1 iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Mar 03, 2009 | Singer Electronic Steam Press Iron
Singer CSP1 Iron Logo
35 people viewed this question
Top Singer Irons Experts
Chance Miller
Are you a Singer Iron Expert? Answer questions, earn points and help others
