Question about GE 36 in. Profile JP960SCSS Electric Cooktop
Problem with large surface unit
The right front surface unit center unit does not come on, only the outer unit works. Everything else seems to work properly.
  • 473 Answers
The element is bad. On some models the elements have a 5 yr warranty. Check your owners manual.
Posted on Oct 05, 2007
Right Front Burner shuts off after 30 seconds. Fault code f153 flashes. I have reset the circuit. Same issue occurs. Any advice?
x9009 Hello and sorry to hear about your problem.
You have a open heat sensor, one 1 of your heating elements.
I suggest you contact a service company for repairs.
I tried to help you, Please help me by vote/rate my response.
Thanks and good luck.
If you live in the Denver Co area, I can help you out
Dec 22, 2010 | GE 30 in. Profile JP939 Electric Cooktop
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
HOT SURFACE LIGHTS
Hold the button down 5-6 seconds and it will go off...then to cut on...press down again for 5-6 seconds and it will come back on.
Sep 06, 2008 | KitchenAid 30 in. KECC506R Electric...
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
Stove problem - outer cirlcle of an expandable element not working
You will need to call a professional these are very complicated and not easy to service, there are no fuses either. It will most likely be the element itself that has failed and they are not cheap. It also could be the switch too however it will take a person very familiar with schematics to properly diagnose it. Or you could just replace the element and switch yourself and that would most likely solve it.
Dec 26, 2007 | Cooktops
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
GE 36 in. Profile JP960SCSS Electric Cooktop Logo
99 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
