Question about Wacker GP5600 watt Portable Generator
FUEL DUMPING FROM CARB - Wacker GP5600 watt Portable Generator
I have a 90 dakota has ran great butthe carb is dumping to much fuel when the gas is pressed and at idle. Will start and idle but put in gear and try to take off and it stalls out any ideas
To clarify, you have fuel injection instead of a carb.
The problem could be a leaking injector, or a problem with the fuel trim including the engine computer.
Is the check engine light on ?
Feb 24, 2015 | 1990 Dodge Dakota
No gas in bubble
Either your fuel line broke and fell off in the tank or your carb is plugged up and needs to be cleaned. The fuel line can be checked by first dumping the fuel out and looking into the tank.
If you see the fuel lines are both intact *(one is long and one is short but both terminate inside the tank) then you probably need to get the carb off and clean it out. Be careful not to use compressed air on the carb as it is delicate. Use a can of carb cleaner only and look into replacing the fuel inlet screen. They come with carb service kits you can buy online for a few bucks.
Be safe and good luck!
Jul 01, 2014 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Parts trouble shooting
float valve is either stucked or debris between valve and seat overhaul carb clean float valve u can dyi or have a mechanic do it for you
Mar 15, 2014 | Cars & Trucks
Why would i get gasoline in engine oil? engine is a 1968 VW aircooled in stock form. Have changed fuel pump and rebuilt carb. Car willo not start without starting fluid.
I think that the only way that can happen is that fuel is getting past the rings and into the crankcase. You have changed the fuel pump, then that leaves the carb dumping fuel into the intake and getting past the rings. The fuel is not staying in the carb and that is why you have to spray to start.
Sep 05, 2010 | Volkswagen Beetle Cars & Trucks
My 97 classic is smoking at idol, and dumping fuel. Carb has been cleaned and the needleand jets have been changed (we even tried smaller ones). It is dumping too much fuel. When we adjust it, it either...
A plugged Idle Jet will give you an erratic idle (up,down,up,down) and also draw in liquid fuel instead of vapor. The 'O' Ring between the float valve seat and carburetor body and the Float Valve are the only two places the fuel may enter the fuel bowl. If the 'O' Ring or Float Vale is leaking the float cannot regulate the fuel level. To test a fuel pump you will need to test for Pressure and Volume.
Sep 02, 2010 | 1997 kawasaki VN 1500 Vulcan Classic
On my 1980 1100 Interstate. I have fuel dumping
Very common problem your fuel system is gummed up carbs need to be cleaned Etc.
May 12, 2010 | 1982 Honda GL 1100 Gold Wing
Looses its prime and needs gas in carb to start
more than likely you have moisture in the bowl of the carb. best bet would be to completly drain all the fuel from the tank and carb and fuel lines and start off all fresh.
Sep 19, 2009 | Garden
Fuel
Hi ...... Sounds like debris in the carb bowl, tap the bowl with a wooden hammer shaft and check to see if it's helped. If not switch off petrol at tank and drain carb. Retry switching on. If that fails take bottom of carb off and check float hasn't split .......... never seen one that has in over 30 years.
Let us know how you get on.
Jan 20, 2009 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
Wacker GP5600 watt Portable Generator Logo
32 people viewed this question
Top Wacker Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Wacker Electrical Supply Expert? Answer questions, earn points and help others
