Question about Danby Silhouette Select Silhouette 15 Inch Wide Built-in Ice Maker W/ Stainless Steel Door
Water runs, no ice however. then after about 15 minutes it just goes back blinking lights
MFI2569VEW water/ice and controls cycle off then on every 15-20 minutes
You need the control board on the back of your refrigerator. This was a problem back when they first come out with this model. Call Maytag and see if you can get a concessions for repair.
Dec 30, 2017 | Refrigerators
What goes a idle position sender do on a 97escort
Low oil pressure switch is designed to cut off engine to prevent damage. If you are sure oil pressure is good when light starts blinking, replace pressure switch. Idle position sender IDK.
Jul 21, 2016 | Ford Cars & Trucks
Need to know how to fix a csw 45 Scotsman ice making machine
Hi, first make sure the switch is not in the clean position but to on. If it is in the on position and the water is circulating over evaporator plate and is running back into the water sump tray and compressor is running as you stated then check to make sure the hot gas valve is not letting hot gas leak through during freeze cycle, the way you can check is after start up wait about 5 minutes and check the temp entering the hot gas valve and the temp on the other side of the valve if temp is the same then valve is bad. The next thing to check is the refrigerant level this only can be done by adding service valves and weighing out the charge to see if it is low, if low then there is a leak. The freeze cycle is as follows. The compressor, fan motor and water pump are all operating and stay in a freeze cycle until the evaporator thermistor reaches 6.5 deg F. That signals the control board to place the unit into a harvest cycle.
Oct 02, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Just bought a 12000 btu standing air condition. Plugged it in and water light comes on . Took out drain plug to check water, no water. light keeps blinking. checked reset and test, light still blinks....
I checked your Owner's Manual and according to it, you have done all the right things. I will suggest one other thing. Turn the unit OFF and unplug it for 15 minutes. Then plug it back in and turn the ON/OFF Switch to ON. During that 15 minute timeout, the electronics should have reset and reverted back to the original factory settings. If it did, the full light should not come ON. If it does, contact Royal Sovereign Customer Support (in the USA) 1-800-397-1025. In Canada 1- 866- 961-6673.
I hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Royal Sovereign ARP-3012 Air Conditioner
The on the door blink off and on and the flapper where the ice cubes are discharged clunks and the lights blink. The only thing I have done is unplug and leave off for five minutes and then plug back...
It will be much better if you leave it switched off for a couple of hours. I believe there is excess ice build up inside the ice maker which has frozen up the tilting mechanism. Letting this ice melt away should solve this problem
Jan 11, 2011 | Amana AFB2534DE Bottom Freezer French Door...
When I press power, light blinks for about 15-20 minutes, then goes off. Press power again, on solid for 30 seconds, then goes off. Press power again, TV finally comes on.
Your television is in need of repair. Hard to tell what exactly needs to be repaired but when the power light blinks in that way then this is the TV's way to tell you it needs to be serviced.
Apr 25, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Danby Silhouette Select Silhouette 15 Inch Wide Built-in Ice Maker W/ Stainless Steel Door Logo
73 people viewed this question
Top Danby Silhouette Select Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Danby Silhouette Select Kitchen Appliances - Other Expert? Answer questions, earn points and help others
