Question about Frigidaire Dryers
Aeqa000fg0 model dryer won't reset after leaving unplugged for an hour. When i plug it in, it shows all the settings and will let me choose the setting i want to dry on, but after a few seconds the drum stops turning. The numbers for minutes to dry stay on. It will not let me turn it off or cancel. All numbers stay lit up.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Unplug for 5 min they re plug it in again and try to start it. Any difference? You did that. Seems the electronic board is not responding.not resetting. You might be in for a new board likely.
If the dryer is more that 5yrs, I would consider a new.
Posted on Oct 18, 2013
yalmer
  • 552 Answers
SOURCE: gas dryer Model MDG9316AWW does not always ignite
First check the exhaust vent to the outside do you have a strong flow of air?
Is the lint passage free of lint? Are the blower vanes clear of lint?
A simple test for the sensors, bypassing the wires to the thermosensor and operating the dryer to test. If the heat now stays on the sensor is usually bad. Also if the flame backs up the safety thermo can kick out to protect against fires. Usually due to plugged lint somewhere.
Posted on Feb 05, 2008
SOURCE: Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Posted on Nov 03, 2008
SOURCE: Dryer will not dry - drum will not turn
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
Posted on Jun 04, 2009
  • 212 Answers
SOURCE: GE Gas dryer. Not hot enough to dry clothes this week.
replace burner assembly
Posted on Jun 20, 2009
  • 291 Answers
SOURCE: wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Posted on Dec 30, 2009
Is there a reset button on a Sanyo 2011 flat screen
most likely depends on the model.
and what are you trying to 'reset'
unplug it for a few min and plug back in
find menu scroll through settings until you find factory reset or something to that effect.
if doesn't reset after unplugging few min leave unplugged over night or as long as possible before using ... most devices reset after a few hours without power
call customer service.
Nov 10, 2016 | Sanyo Televison & Video
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
Feb 02, 2018 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Led lights on control panel are flashing and dryer will not start, check filter light is on
leave this machine unplugged for several hours. Make sure all the lint is free and clear. This machine needs to be plugged for several several hours to reset itself unless your model has a reset option available.
Jun 05, 2012 | LG DLG2524 Gas Dryer
Maytag Dryer MDG6800AWW won't start, lights all on
There is no reset, There will be either a defective solder joint in the controller or the controller is faulty and needs replaced.
Mar 10, 2012 | Maytag Dryers
Dryer won't turn on
turn the breaker on and off.If the dryer is electrical it should be a double breaker (2 switches connected with a small bar across)
Unplug the dryer and plug in after 10 seconds - might reset the electronics
dryer has thermal cutouts for safety so leave it unplugged for 1 hour see if that helps. If it starts and quits again calling service is best solution. We are talking lots of voltage here and fire is not an option
There are internal fuses as well If they blow you definitely have a problem
Todays dryers are more complex and they do need somebody qualified
to service them safely
good luck
Feb 06, 2012 | LG DLEX2901V Dryer
I've owned for approx 3 yrs. Today I was watching a show on my Panasonic TH-50PZ80U and all the sudden the sound went away. From the lowest volume setting to the highest, no noise at all...Please...
Hello!
First move: unplug your broadcast provider's box, wait for a minute, then plug it back into power source. I mean: leave all the connections intact, just unplug from power source. It might be just power cord or power adapter. If that's not the case, please do the same with TV. Unplug it from wall outlet, wait a minute, plug it back in. It's a next step, if your "box" won't take care of the problem. If that won't take care of the issue, refer to owner's manual for "reset" procedure. Worst case scenario: you might need to replace main board inside or your TV.
good luck,
Thanks,
Alex.
Oct 09, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
It won't shut off and the control console shows just green blocks
If that doesn't work, leave it unplugged for maybe an hour.
If you still have trouble, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and detailed your symptoms.
Dec 11, 2009 | GE Advantium 120 Convection/Microwave Oven
Screen shows ''LOCK'' whichever button is pressed
If you still need help, please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit.
Oct 09, 2009 | Panasonic Microwave Ovens
Microwave turns on randomly beeps intermittently displays PAN
Then let us know if the hard reset does not fix it and please reply back with your model number so we can help you.
Sep 07, 2008 | KitchenAid Microwave Ovens
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
