Question about Avocent Computers & Internet
Avocent "black screen" - Avocent Computers & Internet
Were can I find the mac-adress of the 2015 avocent
In windows, connect it and use the "getmac" command under a command prompt .
If on OSx, Open System Preferences from the Apple menu
Click on "Network"
Select your currently active network connection from the left menu (Wi-Fi, Ethernet, etc) and then click on "Advanced" in the lower right corner
Look at the bottom of the window for "Wi-Fi Address", the hexadecimal characters next to this are the machines MAC address
Jun 27, 2014 | AVOCENT-EMERSON Avocent AutoView 2015 -...
How do you connect to a terminal with avocent dsr8035
You should have a DB9 to RJ45 converter in the box. This converter is used to change from DB9 serial to RJ45, which is the port on the DSR that is used to connect to the serial console.
Should you do not have such connector, call Avocent Tech Support, they will help you to get that converter.
The NullModem Cable might also be requiered
Also remember:
9600
8
none
none
Apr 23, 2014 | Avocent DSR8035 KVM over IP Switch KVM...
Avocent 3008 password reset
Avocent Support can unlock the unit.
their support # is 888-793-8763
Jan 28, 2014 | Avocent SMB SWITCHES AUTOVIEW 3008 1 DIG 1...
I have an avocent dsr 1010 16 port switch how do i hook this up at my home
You read the manual and follow the instructions. That's how you hook it up.
Please don't ask such lazy questions when the manual is readily available via a Google search.
Avocent DSR Series DSR1010 User Manual
Jan 19, 2014 | Avocent DSR1010 DSR 1010 KVM SWITCH 16...
I have a problem, i try to access the Avocent ts100 by hyperterminal in winXp, I used a usb to db9 cable but it didn't access to first page or menu, the hyperterminal configuration is 8n1n, only show...
plz
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. report.gif digg.gifdelicious.giftechnorati.giffacebook.giftwitter.pngstumbleit.gif quote.gif
Jul 13, 2011 | Avocent Cyclades TS100 (TES0061001)
Hi, i have a Avocent SwitchView, Tried connecting to a user Monitor, KYB and Mouse then connected two monitor cables in A and B. Nothing seemd to be displayed. By the way i didn;t connect the power.
Hi Steven,
the power is or will be needed. Your unit is a single monitor... are you trying to make it a dual screen setup?
What is the target OS... ? How are you connecting *(USB or PS2) to the PC?
-If you use PS2 you might have to reboot your PC
Is the PC DVI or VGA?
I hope that helps getting you up and running
May 23, 2011 | Avocent SwitchView 10040-SC 4-port KVM...
We have an Avocent ACS32, that we 'forgot' the Admin pwd to.
start the unit single user mode by hitting space after Linux/PPC Load: .... and typing single and hit
use the passwd command to change password and saveconf to save the password
Dec 15, 2009 | Avocent Cyclades Alterpath ACS32 (ATP0105)
Cannot connect to console port
Make sure that the connection port is free.
Mar 22, 2009 | Avocent CCM1650 (CCM1650001)
KVM switch control
APEX switches are manufacturer by Avocent and rebranded by Dell, HP/Compaq, IBM, etc.
The keystrokes should be CTRL-CTRL (Hit control 2 times). Some Avocent switches also use ALT-ALT or SCROLL-SCROLL.
Jan 12, 2008 | IBM NetBAY 09N4290 4-port KVM Switch
Computers & Internet Logo
139 people viewed this question
Top Avocent Computers & Internet Experts
gary433
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
