Question about Baby Gear
One of the handles collapse and now won't snap back in place, It's the babysuite 300 play yard, I've had it for less then 4 months and just started using it two weeks ago, is there anything I could do?
cpenzes
  • 1102 Answers
SOURCE: my toshiba laptop keeps shutting off while i`m using it
check in power options make sure thye are set correctly.
and uncheck for hibernate then click apply
then do a virus scan
restart then a disk defrag
please let me know
Posted on Mar 12, 2009
  • 116 Answers
SOURCE: 1989 heritage softail clutch play at handle
take off your trans door cover and check you snapring on your ball ramp assembly and check to see if all three balls are in place if that looks ok try lubricateing cable also check cable adjuster i had one that the threaded part was cracked where the threads start and every squeeze of the clutch brought a different endplay
Posted on Dec 30, 2009
agent91
  • 2100 Answers
SOURCE: I zeroed in my 25/06 at 100 yards. at 200 yards
It sounds good to me, don't forget, the 25-06 is a flat shooting round, you have your scope pointing up, the bullet crosses the line of sight twice, One at 100 yrds, your zero and the other on it's way down at about 500 yards. You can check the ballistic coefficient of that bullet and see where you need to be zeroing it in at. I would think about 250 yards, will be 1 1/2 low at 100 yards, 3/4 inches low at 200 yards, dead on at 250, then it will start coming down, say 8 inches low at 400 and 18 inches low at 500. Something like that. So your BDC will not be needed till you reach out past 300 yards, which is varmint country stuff. I have my .22 marlin sighted in at 100 yards, and it will put the lights out on anything at that range. You can probably find the charts on line someplace, if you don't have a reloading manual. Check it out.
Posted on Jul 20, 2010
  • 13 Answers
SOURCE: My Toshiba BDX 2500ku won't
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Posted on Jun 20, 2011
heatman101
  • 43501 Answers
SOURCE: my coffee pot is saying prime on it, what does
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 02, 2011
Cant get napper release once its snapped in, is it permenatly locked in?
Hi, turn the handle to unlock, collapse the sides and then the tricky part is toward the bottom of legs finding the other piece to press to collapse them even further.
Mar 30, 2015 | Graco Pack 'n Play
I have a 2007 Chevy Blazer that will not reverse but it will drive forward and all the gears work except for reverse why is this
There is a snap ring inside the transmission on the back. That has come loose or broke, letting the drum move out of place. Remove the drive shaft, remove the tail piece of the transmission. You will see the snap ring or pieces of it. Push the drum forward and reinstall the snap ring. You will have reverse again. You will only get the ring at the junk yard or maybe a transmission shop.
Jun 22, 2014 | Cars & Trucks
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
How do I fold up the playpen
It's a struggle!
Pull up on the handle in the centre of the floor till it is as high as it can go.
On each of the sides there is a plastic piece in the middle. If you feel around them you can find a little button sticking out (it's on the side facing out of the playpen). Push that little button and push down on the middle of the top bar and it should collapse. There are 4 sides to the playpen - and 4 little buttons.
Nov 28, 2012 | Kids II Bright Starts Ingenuity Sleepeasy...
Tracking issues with SONY XAV60
If you smoke or it is dusty in the car, cleaning the laser lens may help. At any rate, if you are careful, cleaning the lens won't harm anything.
Feb 24, 2012 | Sony XAV-60 Car Video Player
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
I don't know how to set up my travel lite crib bassinet
You're not alone. If you do every step perfectly then it's a breeze. Most of us are human and don't... This frequently results in a major pain.
Most travel cribs print the directions on the pad that lines the bottom of the crib. Unfortunately, this still isn't much help. I'm going to assume that you're like most of us- you've read the directions and you still can't get the thing to cooperate!
I fought with my Graco travel crib many times before I discovered a few secrets:
- Follow the directions precisely, even if a step seems a bit odd.
- If you get going on it and mess up (or it just won't stay up), give it up and start over again from step 1.
- Before you start, make sure that it's completely collapsed. It may look like it is, when it isn't. Here's how you check:
There should be at least one handle near the middle of each top pole that can be squeezed (longer sides sometimes have two). Feel your way across the top pole until you find each lever and squeeze it. This will collapse the pole into two (or more) sections.
Make certain that the poles remain collapsed as you pull the center handle (center of crib where matress will go) towards the sky and squish the whole thing together like you're putting it back in the box (or carrying case.) Now we're ready to start!
1) Gently begin to unfold/open the crib as you hang onto the handle in the center.
2) Continue to hold the center handle with one hand. With the other hand, lift each top pole until it locks into one "solid" pole. NOTE: This is trickier than it sounds! If the center handle drops even half-way down then you won't be able to get all poles to lock and you'll have to start over again.
3) Only after all four top poles have been locked, can you push down the center handle. This will spread the bottom into one flat piece and finish locking everything in place.
Good News!: It's all downhill from here!
4) Put a sheet on the "mattress", if desired.
Otherwise, just unfold it and place it in the bottom of the crib. There are some strange little velcro tabs on the sides of the mattress. These fit down the slits in the bottom of the crib and attach to the underside. This step is important as it keeps the mattress in place and helps to reduce the risk of suffocation.
5) Finally, assemble the canopy, locate all the little snaps on the side, and snap on the accessories.
Whew! Take a deep breath... you did it!
Congratulations on your baby! Enjoy!
Jun 24, 2010 | Graco Travel Lite 9001 Crib
My drivers side window quit, where and how do I start to take the door apart to get to the motor? Is it something a handy man can do? I found a motor for $143.00..the fix it place wants 60.00 per hour...
It's not that hard to change the electric motor for the window. Yes, a handy man can do it.
Start by removing the negative battery cable from the battery. Then locate and remove the screws that hold the interior door handles in place (they may be hidden by snap in, or snap on covers).
I personally use a tool similar to the image below to remove the interior door panel; it is held in by plastic snap clips. Try to get as close to the snap clips as possible with your pry bar to prevent them from tearing out of the door panel. Once you have removed the interior door panel, the removal and installation of the window motor will be self explainitory for a handyman. You may be able to find a used motor at a salvage yard for a lot less than $143.00.
99844d1.jpgI hope this helps you, and I wish you good luck on your repair.
Apr 23, 2009 | 1997 Cadillac Catera
Acer Laptop - key topped popped off
Yes it does snap back on. Place it where it on top of the retainer and press down gently until it snaps into place. You may need to work it around a bit in order to line it up. If it doesn't snap on or doesn't stay, check the bottom of the key to make sure the sides where the retainer goes into hasn't collapsed, or check the retainer to see if one of the pins that snaps into the key isn't bent or broken. If the sides are collapsed or a pin is bent, you can bend the side or pin back into place with a small screwdriver, be gentle as not to break it. If it's broken it will need to be replaced.
Jul 16, 2008 | Acer TravelMate 2300 Notebook
Folding up Cosco play yard
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Baby Gear Logo
79 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
