Question about Intermetro 1954 Oldsmobile Super 88 Heater Control Valve Gasket
Where can I buy this gasket? - Intermetro 1954 Oldsmobile Super 88 Heater Control Valve Gasket
  • 2,113 Answers
In grade 9 one of the things we learned in automotive was how to make your own gasket. They sell gasket material at automotive supplies for just this situation.
Posted on Oct 17, 2013
Testimonial: "very helpfull thanks mikadot"
1996 suzuki 750 katana can you buy just the carb bowl gasket and the gas needle valve
Yes you can buy a needle valve assembly which consists of a needle ,o ring,and needle seat.in the UK they are about £40 each !
Apr 12, 2015 | 1996 Suzuki GSX 750 F (Katana)
I changed the gasket but it does not have a tight door close. it closes but it very light to the touch close
You have to form the door gasket. That means you have to use a heat gun (please don't use the heat gun if you are not familiar) to form the gasket to the seating surface. You can use a hair dryer which is less heat intensive. You got to be very careful, since too much heat is going to burn out your gasket and has to buy another one.
This is what you do.... Where the gasket is not seating properly to surface..... Those areas in the gasket you slightly heat up and let the rubber heat up and close the door. So the heated rubber will form into the shape of the seating surface.
Please check some YOU TUBE video's on this before doing. Otherwise you might burn out the gasket and will have to buy a new one again.
Oct 13, 2014 | Sub-Zero Refrigerators
Changing thermostat v6
drain coolant until its below the thermostat.then remove two thermostat housing bolts.remove thermostat housing and thermostat.make note position of thermostat before removing it.then carefully clean all old gasket material from thermostat housing and cylinder block you can buy can gasket remover at any auto parts stores.buy new thermostat gasket.if you have the paper type you need to buy RTV SILICONE to help seal gasket if you have rubber type gasket you dont need RTV SILICONE.make sure both surfaces are clean.then install new thermostat and new gasket.if you have paper type gasket apply thin 1/16 coat RTV SILICONE both sides thermostat gasket.then install gasket to thermostat housing then install housing to cylinder block first make sure new thermostat in place before installing thermostat housing. let RTV silicone sit up about hour before adding coolant.IF THERMOSTAT HAS THE O RING SEAL DONT NEED RTV SILICONE AND THE PAPER GASKET.
Jul 01, 2013 | Mercury Sable Cars & Trucks
How much would it cost to buy a new head gasket for an 86' honda civic?
two ways to buy a head gasket,1 on its own cost 25/30 dollers.2in a gasket kit that comes with all seals and other little gaskets that might be needed cost about a 100 dollers my advice go for the kit.adrian,,,,,,,,,
Aug 20, 2010 | 1986 Honda Civic
Valve cover gasket
Buy the package that come with valves cover gasket and 4 spark plugs tube seals. Its around $10 - $20 and for replace it only remove the pcv valve tube, the sparks plugs cables and ignition coils. Its so easy!! remove the valves cover, only have 10 screws. Try to buy original Plymounth gaskets or Felpro.
Jun 01, 2010 | 1998 Plymouth Breeze
Excessive oil . white smoke over heats guessing
You will go to a Chevy dealer and they will know exactly what you will need. Any auto parts store expects the buyer to know what they want always it seems
Get a set of head gaskets, a intake manifold gasket kit (complete kit) and some silicone sealer, Coolant also and a thermostat & gasket
Apr 11, 2010 | 2000 Chevrolet Venture
Where can we buy door gaskets for our Marine Norcal DE-828 Refrigerator?
Hi..
You want to buy a door gasket, try to visit this site www.ebay.com this is an online selling website. You can chose their what is the brand and model of your gasket. Chose the gasket which is compatible to your old one.
Thanks for using fixya
Regards
ICmanServer
Aug 20, 2009 | Thetford Norcold RV Cooler/Freezer
1999 volvo v70 oil change questions
You can buy a canister wrench at the local auto parts store. You do not need to torque the oil filter on, just hand tighten, No new gasket for the drain plugs just do make sure that it is tightened properly
Feb 10, 2009 | 1999 Volvo V70
Pitted exhaust flange gasket
You can normally buy those from any local parts store or you could get an exhaust gasket maker and make your own its quite simple alls you need to do is trace your old gasket on.
Hope thatl be of help
Dec 17, 2017 | 2001 Subaru Outback
Intermetro 1954 Oldsmobile Super 88 Heater Control Valve Gasket Logo
44 people viewed this question
Top Intermetro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Intermetro Heating and Cooling Expert? Answer questions, earn points and help others
