Question about AT&T 993 Corded Phone
At&t CL84252 I can call out and receive calls but no audible ring.
Had to reset the phone. on in-coming calls it used to say the persons name, where is that set-up
LG Xenon - for adjusting the audible caller announce feature: hit the options menu in the top right corner and select call alert, you can set the phone to announce the name or number of the person calling/texting before the ring.
keywords: call, caller, audible, announce, announcement, announcing, loud, alert, name, person
Nov 13, 2009 | LG Xenon GR500 Cell Phone
When i call someone my voice is not audible to the receiver
who said to do all that. Your problem is with your mike section change it.
Jun 19, 2009 | O2 Xda Atom Exec Smartphone
AVAYA 5610SW IP Phone will not ring, only red light come on
Under the options button. There should be an "Audible alert" option...
Apr 02, 2009 | Avaya 5610 IP Phone
Blackberry 8310 will not ring audibly
To try fixing the mp3 sound, try to play a mp3 file, and toggle the "mute" button on top of the phone. Also try to press the "speaker phone" key (the one with $ sign)
For the audio rings, try to reset the phone by taking the battery out for 1 min then put it back in.
Hope this help.
Dec 29, 2008 | RIM BlackBerry Curve 8310 Smartphone
Instructions for super nintendo games on the intrenet
Here is the controller instructions for "John Madden Football"
CONTROLS KICK OFF Y Button call onside kick formation B Button kickoff, activate closest defender A Button call audible RECEIVING ONSIDE KICK Y Button attempt to receive kick on the left side of the field B Button attempt to receive kick in the center of the field A Button call audible, attempt to receive kick on the right side of the field OFFENSE BEFORE THE SNAP X Button fake snap B Button hike ball A Button call audible OFFENSIVE AUDIBLES X Button cancel audible Y Button running play B Button anti-blitz play A Button trick play OFFENSE AFTER THE SNAP Y Button dive B Button break tackles A Button spin PASSING X Button pass to receiver in window x Y Button pass to receiver in window y B Button show passing windows, pass to receiver in window x A Button pass to receiver in window a RECEIVING, RUNNING X Button reach for catch Y Button dive B Button break tackle A Button spin DEFENSE BEFORE THE SNAP B Button activate defender A Button call audible L or R Button line surge DEFENSIVE AUDIBLES X Button cancel audible Y Button stunt B Button blitz A Button defend against run DEFENSE AFTER SNAP X Button reach Y Button dive B Button activate defender nearest the ball A Button power tacklehttp://www.allgame.com/game.php?id=2510&tab=controls
Nov 23, 2008 | Video Game Consoles & Games
No ringinh
You can check what profile is selected by pressing the red button once while the phone is in standby mode. Then try to change the profile to General or Loud. If that is OK then try this: go to Menu/Settings/Tone settings/Ringing volume and set it to the maximum value.
If that doesn't help please let me know and I'll try to find some other solution.
Sep 08, 2008 | Nokia 1100
I CANNOT MAKE MY PHONE HAVE RINGER VOLUME WHEN I RECEIVE A CALL
Did it EVER ring on outside calls? It may NOT be programmed to ring
Apr 15, 2008 | Panasonic KX-T7630 Corded Phone
Audible ring has changed/machine won't answer when called
It is to do with "smart ring" feature or in your area called "distinctive ring" feature. The machine won't receive unless the ring pattern matches your distinctive ring pattern. If you are not using that feature, then you must turn the feature off. Then set your receive mode to "fax tel" mode if it is your only line.
Jan 16, 2008 | Brother IntelliFAX 2800 Laser Fax
AT&T 993 Corded Phone Logo
142 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
