Question about Belkin Components Keyboard Folio for iPad
My belkin keyboard is mistyping. A is Q. 2 is e . is; etc. how do i fix it
  • 9,098 Answers
Unplug it, then plug it back in to reset it.
Posted on Oct 17, 2013
Keyboard mistyping issues
1. Change to United States-International keyboard layout.
Manually change to United States-International keyboard layout
2. Use the Microsoft Fix it 50558
3. Confirm if the Keyboard is wired or Wireless
Information:
Ensure that batteries are new for the wireless keyboards as drained batteries can
cause delay.
Slow computer can also cause the issue. Check if computer is slow and perform necessary troubleshooting steps related to performance after following below provided troubleshooting steps
Steps:
Clear Turn on Filter Keys, or adjust the settings to a quicker rate for Windows Vista and Windows 7
Clear the Use Filter keys check box, and then click OK for XP
adjust your keyboard's repeat delay and rate settings
Drag the Repeat delay: slider to Short
Drag the Repeat rate: slider to Fast
Click OK.
Close all windows
Is issue persists, Reinstall the Drivers
Follow below steps :
http://www.wikihow.com/Fix-a-Keyboard-That-Has-the-Wrong-Characters
Mar 22, 2014 | Dell Inspiron 1525 Laptop
Belkin keyboard fix
check the battery and the reciver is enough close?
Dec 06, 2012 | Belkin Wireless Keyboard/Optical Mouse...
Hi i have a belkin f8e8e8-kdb, wireless,, i need the owner manual
The closest number to that I could find was F8E838.
If this is the right model here is the PDF manual.
http://cache-www.belkin.com/support/dl/p74669_f8e838_man.pdf
Hope this helps.
Mark
Nov 17, 2009 | Belkin Computers & Internet
How do I get my belkin keyboard to acknowledge the top row functions etc favourites music folders. They used to work and now they don't. Either does the home and end buttons. Thanx in advance
You must have got a CD with the keyboard. Just insert it and install the software. The keys would work again. If you do not have the CD, let me know the model of the keyboard and I will be able to give you a link to download the software.
May 13, 2009 | Belkin Wireless Keyboard/Optical Mouse...
WHERE IS THE RESET BUTTON ON MY WIRELESS BELKIN KEYBOARD ANTONE??
had the same problem and tried pressing down the connection button on the keyboard at the same time as the connect button on the receiver. If you press down on both intermittently then they should pick up each other.
It seems there isnt a reset button like there is on the mouse, which is what i was looking for on the keyboard - i presume they mean the connection button / LED light but you have to press the receiver button at the same time.
good luck!
Mar 02, 2009 | Belkin Wireless Keyboard/Optical Mouse...
PS/2 to USB adapter
does windows recognise the new hardware and install drivers for it when you plug the wireless sender in to the laptop ?
try opening up device manager and see if the deive in question has an exclamation point over it , if ti does remove and reinstall
hope this helps
Dec 31, 2008 | Belkin Wireless Keyboard/Optical Mouse...
Key bord problem
Remove keyboard in device manager and reboot. This will reload drivers. If that doesnt help you have to replace keyboard. Good luck
Dec 29, 2008 | Compaq Presario Notebook
Belkin wireless keyboard receiver won't work with my laptop
Yes and no...
"Wireless enabled" means you do not need a separate adapter to connect to a wireless NETWORK or computer, not a peripheral device.
I assume the two connectors are PS/2- plugs - one pink, the other one green. What you need is a PS/2- -to-USB adapter that should have come with your keyboard. PS/2-in, USB-out, either with or without the cables (see picture)
Dec 18, 2008 | Belkin Wireless Keyboard/Optical Mouse...
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
Belkin Wireless Mouse
Today I tried pressing the reset button on the bottom of the mouse, and at the same time pressed the button on the top of the remote reciever. I'd pressed both in the past, but never at the same time. This seems to have fixed this problem. I hope it's a solution for others also.
Dec 21, 2007 | Belkin Wireless Keyboard/Optical Mouse...
Belkin Components Keyboard Folio for iPad Logo
111 people viewed this question
Top Belkin Components Computers & Internet Experts
William Miller
William Miller
David Payne
David Payne
Are you a Belkin Components Computer and Internet Expert? Answer questions, earn points and help others
