Question about Whirlpool RF263LXTS Range
Whirlpoot RF263LXTS burner goes from zero to hot
No Hot Water
change your thermocouple; it is the brass colored pencil like metal rod that sits over the burner and has a tube attached to the end of it the tube goes to the main gas valve; unscrew the thermocouple at the gas valve and remove it the main gas valve opens when the thermocouple gets hot by being in the pilot flame
Jan 22, 2014 | Noritz Water Heaters
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Burner lights for 10 min then goes off
replace the 2 solenoids on the gas valve will solve the problem
Aug 08, 2012 | Maytag SDG4606A Gas Dryer
Replacing oven light
they can get stuck try a small filter wrench or a large channel lock with a rag
Jan 07, 2010 | Whirlpool RF263LXTS Range
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
One of the burners on my Jenn-Air electric cooktop does not turn on and get hot. 3 burners do work. Any suggestions?
the contact may be loose but most likely the burner needs to be replaced. the one you use the most usually goes first, and not getting hot enough is the common indicater of a shot burner
Jul 09, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Burner flame shuts off during use and then you smell gas
all ovens, when they reach temperature they go off and on to kip the temperature, but if you smell gas the oven ignitor needs replacing, the ignitor gets red hot to ignite the burner ,but when ignitor does not get hot enough, it will have a delayed, that's the reason you smell gas.
Dec 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Whirlpool RF263LXTS  Range Logo
14 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
