Question about KitchenAid Refrigerators
Have KBRS19KTWH refrigerator and have a problem with ice build up in the bottom of the freezer.
aborcass
  • 2651 Answers
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
aborcass
  • 2651 Answers
SOURCE: Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 20, 2008
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
  • 109 Answers
SOURCE: Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Posted on Oct 22, 2009
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Posted on Dec 14, 2009
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Ice acumlating in bottom of freezer drawers..ice build up...icing up products in freezer, and keeping the drawer from closing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Viking DFBB363 Bottom Freezer Refrigerator
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Mar 21, 2008 | Refrigerators
Refrigerators Logo
119 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
