Question about Samsung HP-R5072 50 in. Plasma HDTV
I,ve got a Samsung plasma display tv model PS42B430P2 and it do not switsh on although the red remote light is on. If I swtake the powersupply off and put it on again the red light started blinking for six times goes off and then lights up again without blinking. If I press the start button on the remote there is some flickering going on on the red light but nothing happens. Email:kobuss@gmail.co.za. Thank you
5 Suggested Answers
SOURCE: remote control
take the batterys out of the remote and hold the power button down for 10 seconds then put the battterys back in and it should work. good luck
Posted on Apr 16, 2008
Shuttle83
  • 1139 Answers
SOURCE: No Video, No Sound
Hello, This might be a board with a loose connection or a faulty capacitor on the power board or one of the immediate circuits attached to the power supply board. I would suggest that you have this serviced by a qualified TV Technician. However if you wish to do this yourself, you need the following equipment: 1) Multimeter (to measure the voltages; AC and DC on the various test points on the boards) 2) Oscilloscope (to measure the startup and shutdown circuit ramp voltages) 3) Isolation Transformer (to isolate the Tv from the AC circuit that the test equipment is on) 4) Service manual or schematic diagram (to show where the test points are and what signals and voltages to expect) 5) Signal generator (to generate reference signals for servicing the TV) Now if you know how to use these pieces of equipment your are ready to start, if not again I would advise you to have the set checked by a qualified TV repair technician. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 10, 2009
lukster
  • 217 Answers
SOURCE: first lost pic now no sound replaced main
YOUR OTHER POWER SUPPLY IS GOOD, YOU NEED TO REPLACE THE Y-BUFFER AND Y-MAIN BOARDS
Posted on Dec 30, 2009
  • 184 Answers
SOURCE: My Samsung HdTv will not
Hello, You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, If you need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where. power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help to solve the problem
Posted on Aug 27, 2011
I have a Samsung Plasma TV (pn60f5300afxza) and when i try to open my TV there is nothing on the screen and the red light flashes. The screen doesn't open or nothing.
Samsung remotes sometimes have buttons up the top of their remotes to control other devices. I accidentally hit these sometimes and they change the controller to another (not connected). Ensure TV Button on top of controller is pressed before using remote to turn on tv.
Nov 07, 2016 | Samsung Cell Phones
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
Hello, I have a Samsung plasma TV PS42B430P2 that no longer works properly. In fact when I turn on Quelqyoues minutes later I can not control it with the remote and the volume goes up and down without...
My experiances, that problem came from shot capacitors on pcb switch touch.
If you can DIY , open and remove capacitors on it. If you can't do it, call tech samsung for replacing assy touch pcb.
Good luck.
Apr 19, 2011 | Televison & Video
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
Aug 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Hi my samsung lcd tv model le40s8, it won't switch on when i press the power button on the remote the red light starts to flash and it makes a clicking noise and won't turn on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Aug 17, 2009 | Samsung LN40A450 LCD TV
Please Help!! Black Screen, Red Light Flashing
is this a plasma or a dlp tv? if is a dlp a have bad news for you get rid of the tv, if is a plasma then is something different, post the model # anyway to see if we can help you.
caypianan@yahoo.com
Aug 24, 2008 | Samsung FPT5084 50 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
133 people viewed this question
Jerry Greenberg
Jerry Greenberg
