I have the Digistat +2RF system. During the day all works well. But at night I get the red flashing light and error button. I have tried the reset problem with pressing the number 2 override then the number one etc etc and all resets fine. I get the correct lights coming on etc etc. I get a click but the BAXI combi boiler does not fire up. It all works perfect during the day. Any solutions anybody. Thank you. Drren
  • 208 Answers
SOURCE: How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
Posted on Dec 20, 2007
SOURCE: Daewoo DF4700P
Model No DF 4700P
Posted on Jan 02, 2008
Ashlesha
  • 7 Answers
SOURCE: silver ps2, red light only, no power up
The live wire may be detached,
SoThere may be an internal problem and You can show it to a mechanic nearby you.
Posted on Jan 25, 2008
ginko
  • 19396 Answers
SOURCE: I want to shut the
Do you have a unique timer for the two boilers?
Posted on Sep 11, 2008
tborn6
  • 700 Answers
SOURCE: Boiler problems
heres a copy of the serviceing manuel for the unit. just click on the link and download the manual. http://www.ariston.co.uk/uploads/doc482c2cada6e71.pdf good luck
Posted on Jan 11, 2009
.Can not take pictures at night with my Moultrie 1100i trail cam. I was informed that there are numerous SD cards that should not be used.
Not being able to take pictures _at night_ likely has nothing to do with your SD card. If the SD card works during the day, it should be fine at night, too.
Any camera needs some light to take pictures. Many use flash to take night time pictures, or infra-red (IR) lighting. I don't know your camera well enough to know if you have either or how to configure how to turn that on.
Nov 11, 2015 | Max Electronics - Others
I need red light phone number of dussledorf
Hello, First, don't turn on this Night Owl NODS3 during the day...Bright lights will destroy the image intensifier tube in mill-seconds. It used on during the dark hours of the night and look at bright city lights on the poles on homes.
You have two button; one with have o/1 (on/off) then the second but would be the IR light and it will have the IR on and some time there will be another button mark A and this button is used to enhance the image.
To turn on the button--all you have to do is to push it. Only in a dark room with IR button on. and only in the dark of the night. If it doesn't work then let me know drawbridge21@q.com send me a message. GB...stewbison
Sep 14, 2011 | Night Owl Optics Optics
I have recently bought a night owl monoculal, but on fitting a new battery only the power light comes on, the infa red does not come on?
Hi, did you push the IR button? Read the operator manual about looking directly into bright lights and trying to see thing during the day time. This a NO, NO. It made for night vision. stewbison
Dec 28, 2010 | Night Owl Optics Explorer NOCX3 Monocular
Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Oct 27, 2009 | Heating & Cooling
Red alarm light on constantly and heating wont work unless over ride system
Have you tried turning one of the thermostats off.? They are both talking to the same unit and they may be arguing with each other.
May 21, 2009 | Dayton Water Heaters
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Single red light flashing
Needs 3 red light repair. You can contact us at xbox360fixer@verizon.net
THanks
Jan 03, 2009 | Microsoft Xbox 360 Console
My Drayton Digistat RF3 boiler control is not working. The thermostat module indicates it is sending a signal, but the unit beside the boiler has a red alarm LED lit. I've removed the batteries and turned...
I found that this solved the problem hope it helps you too.
come back on}
seconds.
received.
Nov 04, 2008 | Heating & Cooling
Iflo digistat+2RF remote control for combi boiler
there should be an overide button on reciever try checking if stat is still communicating with reciever when stat is turned up and down light should flash on reciever
Oct 23, 2008 | Lasko 5540 Ceramic Compact Heater
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
