Question about Comfort Zone Heating & Cooling
The infrared wont turn on , no heat - Comfort Zone Heating & Cooling
  • 2,113 Answers
Because it is an infrared... It likely uses a common heat lamp bulb. (yes just like in the restaurants where they keep your entree warm until picked up by the waitress, or the type in a chicken coop). Locate and replace the bulb.
Posted on Oct 18, 2013
After heating up the engine, when you shut it off i wont start anymore, what is the defect?
Sometimes plugged cats can severely overheat expanding the catalyst material and blocking normal aspiration. if it starts ok when cool, check cat temps when running with infrared non contact thermometer. bad cats will often display temps in excess of 500 degrees. cats are built into manifolds on the six cylinders, one front one rear. sometimes heat shields prevent a good measurement.
Mar 29, 2016 | 2004 Hyundai Santa Fe
I have a GloWarm propane/lp gas space heater. Can I use bottled propane tanks?
no you can't, and aren't you worried about carbon monoxide poisoning? Where does the burnt air go?
GloWarm Heaters - ventfree infrared heaters
GloWarm Infrared heaters are residential gas space heaters that are ventfree,
so no venting is required
GloWarm Plaque Infrared heaters direct heat from radiant plaques that
"warm like the sun."
Infrared heaters heat objects in the room before the air,
making them ideal for un-insulated rooms in your home.
All propane heaters require a 100 lb. tank or larger!
GloWarm Heaters ventfree infrared heaters
Oct 27, 2015 | Heating & Cooling
Not sure if a blower is in this model because feel no air comeing from unit
The blower is/was a $69.00 optional add on feature for that heater. To be quite honest, a blower does little on an Infrared Heater. Infrared, unlike Blue Flame Convection Heaters, doesn't waste energy heating the air. It heats objects (floor, walls, furniture, etc). From that the room air heats up. Simply put, it heats a room like the sun heats the earth. It's really more efficient than a gas convection heater. Rated 99.9% efficient at 15,000 Btu's, it will heat a good sized room easily.
I've selling these heaters for several years and I always try to talk the customer out f wasting their money on a blower. It's simply not needed on an infrared heater.
I hope this helped you and thanks for choosing FixYa.
Aug 20, 2011 | Empire ECS HearthRite HR25EL Heater
My sonyericsson k800i is not turning on
it may have a problem on the battery. if not, then it need to pre-heat on it's ICs...
May 21, 2010 | Sony Ericsson K800i Cellular Phone
Rinnai gas water heater wont heat the water hot enough even though we have turned the thermostat up to 185.
your temp control is bad and you will have to have a tech to service the unit, contact rinnai and they will give you info on a quilified repair person,, not just any one should be allowed to work on it,, depending on the age it may still be under warranty,, they come with 5 year parts 1 year labor 12 years on heat exchanger this is on all rinnai units
Feb 18, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
MY heater So noisy
grease the bearings before you burn your house down.
Jan 04, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
269 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
