L6 is blinking on the Sharp AL-2030 Copier - Office Equipment & Supplies
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to montgomery@brturbo.com.br
Posted on Feb 15, 2008
jaylex
  • 417 Answers
SOURCE: AL-1340 flashes L6
I think L6 means that it is not warming up you will either need a new fuser or control board to be honest I would say beyond economical repair.
thanks J
Posted on Feb 17, 2008
VonZeppelen
  • 60 Answers
SOURCE: Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Posted on Feb 27, 2009
  • 990 Answers
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Posted on Aug 19, 2009
Sharp Tech
  • 63 Answers
SOURCE: Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Posted on Oct 16, 2009
Testimonial: "Wow! A solution to my problem with a copier was posted within a couple of hours, and the procedure worked perfectly! Thanks. OB "
What does an L6 error code on Sharp AL-1041 Digital Laser Copier mean?
Polygon mirror motor problem. Call or take the copier to your local dealer for repairs
Apr 14, 2017 | Sharp Office Equipment & Supplies
Clearing service man on 5320 sharp copier
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
Nov 16, 2015 | Sharp Office Equipment & Supplies
Blinking L 6
L6 is a polygon mirror lock code. Laser unit trouble. Check all connections. Replace LSU
http://www.precisionroller.com/search.php?q=al1000+laser
Almost better to replace machine?
Sep 01, 2010 | Sharp AL-1000 Copier
It is a Sharp al 1000 with error message L6 which means Polygon mirror motor not up to speed? How is this fixed and what cost?
Since the polygon motor is part of the laser unit, it would cost about $200 plus labor to replace it
Jun 14, 2010 | Sharp AL-1000 Copier
NEED HELP WITH SHARP AL-1010
Hello sir; According our service manual 'L6" sub code 10 is laser drive, motor, problem, replace laser unit . the laser unit item# is DUNTK0013QSZZ, it located at left hand side of the toner cartridge inside the machine.
Jan 23, 2009 | Office Equipment & Supplies
STAUS INDICATOR SHOWS "L-6" ON SHARP AL-1010
Dear sir; The L-6 error code it means "laser drive, motor", It can be reset, the procedure as follow;
1, press "clear", "exposure mode", "clear", "exposure" those keys.then machine go dead.
2, enter 14, then press print.follow the direction willtake car the problem.
If you need more help just let me know I'm always around, or generously give me good rating. thank you,
HAVE A MERRY CHRISTMAS !!!
Dec 23, 2008 | Sharp AL 1215 Black and White Copier
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
14 people viewed this question
jasbo
jasbo
