Question about Whirlpool GD2SHGX Refrigerator
Replace ice dispensing motor on whirlpool refrigerator w10215646 and need wiring information on male/female connector. two wires into the female connector and one wire pulled out of it (could be ground wire)
Sea Breeze
  • 4654 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
  • 531 Answers
SOURCE: Whirlpool GS6SHAXMB00 ice dispenser not working
remove the ice bin close door and push for ice and hear if the motor working if motor not could be door switch if motor working is the solideo valve
Posted on Mar 31, 2009
SOURCE: Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
Posted on Aug 26, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool refrigerator ice despenser
To All With This Same Problem ,
Remove the top freezer door hinge cover ( 1 screw holding it on ) , and disconnect the plug there . This will disconnect the power to the door dispensor .
Using a butter knife or small screwdriver , insert it in the bottom of the dispensor cover between the grill and the cover .
Push down and in wards , to force the bottom of the cover outward , being careful not to break the 2 or 3 built on plastic clips on the cover .
After the lower portion has been disconnected , lift the cover up to disconnect the top clips and then remove the plug on the cover .
The white piece on the dispensor now visible , is the bracket control .
The switch on the right side , is for water , the switch on the left side , is for ice . Usually , the ice switch , has a broken " spear " , which holds the switch in place . The whole bracket control , pt # 2180226 , will have to be replaced . Only 2 or 4 screws hold it on .
This part is easily replaceable by the consumer .
Just be careful when installing the switch , not to break the new " spears " and be sure to reinstall the plastic " spacers " in the same spot on the new bracket .
When reinstalling the dispensor cover , slip the top on first , and just lightly " pop " the bottom back in place .
Posted on Oct 09, 2009
My dial pad don't light up water leaks from hose water don't dispense ice maker works fine
Check the wiring beneath the hinge cover where there is a connector male/female connection to insure it is firm. Please list a model number. Model numbers would come in handy because not every refrigerator is the same, Thanks
Appliance 911 Sea Breeze
Aug 09, 2015 | Refrigerators
How to bypass air conditioning compressor on 2002 ford taurus?
You would need to replace the compressor with an A/C illiminator bracket/pulley, you cannot just put a shorter belt as it would still make contact with the a/c pulley, at least on a 3.0L OHV version.
May 27, 2014 | 2000 Ford Taurus
I have a whirlpool refrigerator GI5FSAXVY02. The water button won't light but when pushed it makes the it makes the filter replace light and cooling light come on? It dispenses ice but no water.
Sounds like a short circuit either in the dispenser keyboard, wiring where a wire connector and where the wiring comes out of door. Do you have an OHM meter? W10162500 Low Voltage Dispenser Control Board and the W10315980 Keyboard Overlay
Here is the GI5FSAXVY Tech Sheet below with a wiring diagram.
If you need help please let me know. I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 13, 2014 | Whirlpool GI5FSAXVY Stainless Steel ...
You can change the connectors on the wiring loom there are only two wires per valve
this video might help
Jul 22, 2013 | Whirlpool duet Washing Machines
A CH pressure sprayer PW175000AV Ser# 00842 was electrically taken apart without noting how wires were to be reattached. There are 4 male spade connectors on rocker switch which works fine. Power has...
Hello Woodnflies,
I understand that you need to rewire your pressure washer. I understand that you already have the switch wired and the motor wired as they are working. You need to power the pump that has a white (common) male and a black (hot) female. You what spade connections do you have open to connect too.
You should have a black and a white that have nothing attached to them this is where the pump wires are going to attache in the circuit.
Thank you for choosing FIxYa.com
Justin
May 05, 2011 | Campbell Hausfeld PW1750 Electric Pressure...
Kenmore Coldspot Ice dispenser quit dispensing. Model #59592990 makes ice, but the motor in the back will not turn to push out ice or crush it.
the motor could not be receiving power check it's male and female plugs weather they are joined.or the motor needs replacement
May 12, 2010 | Refrigerators
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Westinghouse LF708C fault code SE. not spinning. what needs to be fixed?
SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
Jan 22, 2010 | Westinghouse Washing Machines
M/n gs6shaxmq00 s/n sp4654020 whirlpool refrigerator not dispensing ice cubes through chute. Auger motor also not coming on. Suspect circuit board but need wiring diagram to test. Switch is pushing in and...
I would like to work with you with this. At the moment I have found the wiring diagrams for your model. And here is first=> http://www.servicematters.com/docs/wiring/Wiring Sheet - 2255955.pdf
Try looking over that and if you have more question please let me know. One person I trided to help said not helpful before I could get back with the parts and things to look for. If you need more assistance please contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side not making ice
the proble is most likely in the wiring connector that is located under the plastic cover on the top hinge,remove the one screw holding it on and remove the cover to get to the connector.I had to ben the male end of the wire connectors slightly to get a good connection
and plug it back in.
Dec 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool GD2SHGX Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
