Question about Gateway Recertified - ZX4250G-UW308-FB-R 20" All-in-One PC Windows 8
How would you hook up a printer to this computer since there is no cd drive for the software disc? Are there any printers compatible with this unit?
  • 2,113 Answers
I often download and install software from my hard drive. Go to the manufacturers site to get the software. I only use HP printers and can get software for almost anything from them.
Posted on Oct 17, 2013
Error says that ocr is not installed
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
I hope this helps.
Feb 01, 2012 | Lexmark All-in-One Printer with PictBridge
How do i hook up to new computer
usually , you would follow the quick installation notes. but generally if a usb printer you run the cd that comes with the printer and follow the instructions. at some point during the installation of the software you should be prompted to connect the printer to the computer and switch on the printer.
it is usually a mistake to connect the printer before running the installation cd. if you do not have the disc , you should be able to find installation software/drivers from the hp.com website if you search on the printers model number.
Dec 19, 2010 | HP Office Equipment & Supplies
I have a netbook computer which comes without a cd drive and I want to install my printer
There are two methods to install the printer driver.
1. Purchase or borrow an USB external CD/DVD drive connect it to the mini laptop's USB port and install the software from this drive.
2. Use a different computer and copy the contents of the CD to an USB memory stick and then plug it into the mini laptop's USB port and install the software from this USB memory stick.
Mar 22, 2010 | Lexmark X1270 All-In-One InkJet Printer
Trying to add printer to computer it asks brand and gives lists of models my canon pixma mp130 isnt there what should i add it under what is it compatible with?
Install the printer software for your operating system. Drivers will be installed and Windows or your OS will recognize it.
Hope it helps.
Sep 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Unable to check cartridge ink level on new computer.
i think the problem is on that software.pls check the software cd or DVd. if it is fully compatible with windows vista.
Jun 13, 2009 | HP OfficeJet 6310 All-in-One Printer...
Asus Eee 8.9 4GB compatible with Lexmark x2470 all in one printer
hey rose, I'm afraid a normal user won't be able to hook up those old drives to eee. However, you do not need a cd-rom to install the printer drivers. Just download them from lexmark.com homepage and install them from your hard disk! =)
Here's a direct link to the vista driver for your version:
http://www.downloaddelivery.com/downloads/cpd/cjr2400EN.exe
hope that helps! cheers
Jun 10, 2009 | Lexmark X2470 All-In-One InkJet Printer
Mac OS 10.5 Leopard
two issues here..
compatibility of Epson with Leopard..and also the drivers will need to be postscript compatible..not an easy task.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Epson Stylus R380 InkJet Photo Printer
Compatibility with printer/scanner
Insert the printer software disc into your drive and try to follow the directions from there. Before that you should disconnect the printer from your computer.
Apr 01, 2008 | Office Equipment & Supplies
Printer prints garbage
Did it ever work on new system or never has. Sound like either a software conflict or similar but most likely it doesn't like new machine specs. Have you made sure no other printer software is accidentally installed. Are specs for new system and printer compatable. Some manufacturers specify their machines specifically do not like certain OS's and specs. Because pc and software tech is going so fsat it is really hard for manufacturers to keep up, just as they run off their new printer, state of the art, microsoft brings out a new OS etc, and voila, a new updateddriver is needed. Have you considered it may be the pc causing the errors, ie the registry (from malware,spyware etc) not allowing proper installation. This can and does happen. Just last week, my friends printer was perfectly fine, she had some spyware and we had to edit the registry as it had corrpted where the printer was installed but also her cd rom drive icon and use were wiped out. Run antispyware virus and registry scans to eliminate these. Also try installing printer off a back up copy of the disc not original, good luck.
Mar 02, 2007 | Lexmark X4270 All-In-One InkJet Printer
Gateway Recertified - ZX4250G-UW308-FB-R 20" All-in-One PC Windows 8 Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
